Pyboard based GSM phone.
jeffm
Post by jeffm » Fri Nov 10, 2017 9:39 pm
I have implemented a basic GSM phone using a pyboard, the LCD160CR display skin and a SIM800L GSM module. The phone implements voice calls and composing, sending and receiving SMS messages. It operates from a small (800mah) Lipo battery which lasts for around a week in standby mode.
I looked at using @pythoncoder’s impressive LCD160CR UI library, however, it proved to be overkill in terms of resources as the phone interface is primarily buttons and text labels. You really need to use a stylus (i.e. matchstick) to use the SMS text entry keyboard. The code and details can be found at:
https://github.com/jeffmer/micropython-upyphone
The following images give a flavour of the touch screen interface. More together with an explanation of the operation can be found in the github repository.
rcolistete
Re: Pyboard based GSM phone.
Post by rcolistete » Sun Nov 12, 2017 10:29 am
Fantastic ! A GSM phone with MicroPython and only 100 KB of free RAM !
Post by pythoncoder » Mon Nov 13, 2017 8:40 am
That is most impressive and must have taken a good deal of effort. I'm amazed you managed to fit a qwerty keyboard on that display in portrait mode. And that the touch overlay is sufficiently precise to support it.
Perhaps there is a case for a mini-gui for the LCD160CR supporting a subset of the features of mine but consuming less RAM - but when you write a library it's hard to assess how many people actually find it useful.
jeffm
Post by jeffm » Mon Nov 13, 2017 10:03 am
@pythoncoder
The accuracy is outstanding and much much better than some other cheap resistive touch screens that I have. There is occasionally some jitter on touch but it quickly settles on the pressed key. The trick is to ensure that the desired key is highlighted before releasing it.
SpotlightKid
Post by SpotlightKid » Wed Nov 15, 2017 11:06 pm
This project was also highlighted in one of the Python newsletters I have subscribed too. Very impressive!
rcolistete
Post by rcolistete » Fri Nov 17, 2017 12:51 pm
Russian news/article about uPyPhone :
http://www.cnews.ru/news/top/2017-11-14 ... rtfon_s_po (in Russian)
https://translate.google.com/translate? ... rtfon_s_po (translated to English)
jeffm
Post by jeffm » Fri Nov 17, 2017 8:01 pm
Yes, I saw this quite bizarre article. The developer Alexei mentioned in the article has a Github account which has a forked version of my repository as indicated in https://github.com/AlekSi/micropython-upyphone.
jeffm
Post by jeffm » Wed Nov 22, 2017 3:45 pm
Now updated with internet access over GPRS. The sim800l now includes a urequest like interface to the SIM800L module's HTTP AT interface. This allows both http and https requests. Using these I have implemented two example applications. The first fetches and displays currency exchange rates - the code is very similar to that posted by @mcauser for his Bitcoin display. The second application fetches and displays weather information using the wunderground api - see below:
The icon is a JPEG converted from the usual wunderground GIF icons. It would be nice to be able to display GIFs directly on the LCD160CR - any suggestions as to how best to do that?
