building PYBv1.1 binary double FP + threading
microzee
Post by microzee » Thu Nov 30, 2017 1:22 am
I have found the binaries for the PYBv1.1 which include threading and double floating points in the downloads section on the micropython website.
However I'm wanting to be able to build the binaries myself and am have a bit of trouble with it.
Can anyone help or provide the required Makefile/configuration etc changes required to get these features to build.
torwag
Re: building PYBv1.1 binary double FP + threading
Post by torwag » Thu Nov 30, 2017 5:18 am
you will find everything you need on github.
https://github.com/micropython/micropython
SpotlightKid
Post by SpotlightKid » Thu Nov 30, 2017 8:04 am
Enabling these options is not documented in the READMEs in the repo, AFAIK. Enabling double floats should be the MICROPY_FLOAT_IMPL=double define and threads MICROPY_PY_THREAD=1.
Never tried it myself though.
Post by Roberthh » Thu Nov 30, 2017 9:00 am
All options that can set set or unset are defined in py/mpconfig.h. This file also defines the default values.
SpotlightKid
Post by SpotlightKid » Thu Nov 30, 2017 3:02 pm
When I try to compile the firmware for the Pyboard V1.1 with double floats and thread module, using the command line in ports/stm32 and setting #define MICROPY_PY_THREAD (1) in py/mpconfig.h:
LC_ALL=C make BOARD=PYBV11 MICROPY_FLOAT_IMPL=double V=1
I get the following error:
CC ../py/mpstate.c
gcc -I. -I.. -Ibuild -Wall -Werror -Wpointer-arith -Wuninitialized -std=gnu99 -DFFCONF_H=\"lib/oofatfs/ffconf.h\" -Os   -fdata-sections -ffunction-sections -fno-asynchronous-unwind-tables -c -MD -o build/py/mpstate.o ../py/mpstate.c
In file included from ../py/mpstate.h:32:0,
                 from ../py/mpstate.c:27:
../py/mpthread.h:36:10: fatal error: mpthreadport.h: No such file or directory
 #include <mpthreadport.h>
compilation terminated.
make[1]: *** [../py/mkrules.mk:47: build/py/mpstate.o] Error 1
make[1]: Leaving directory '/home/chris/work/micropython/micropython-mine/mpy-cross'
make: *** [../../py/mkrules.mk:107: ../../mpy-cross/mpy-cross] Error 2
What is the correct way to enable the thread module?
jickster
Post by jickster » Thu Nov 30, 2017 9:14 pm
CC ../py/mpstate.c
This isn't like merely setting a MACRO to 1.
First of all, there's reason why the header is called mpthreadport.h: threading is very OS specific and even possibly hardware specific. If you search for one of the functions in mpthread.h like mp_thread_start(), you'll see it is defined in three different ports: cc3200, stm32, unix.
Furthermore, if you drill down further, you'll see that in the stm32, the port is specifically for FreeRTOS i.e. unless you're using FreeRTOS on the stm32, the "stm32 port for threading" is not usable to you.
Assuming you're running FreeRTOS, to make the BUILD work, you have to defined MICROPY_PY_THREAD as 1 in mpconfigport.h (or mpconfig.h) which it looks like you've done since you got the include error.
mpthreadport.h is located in \ports\stm32\
If you launch `make` from that directory,
SpotlightKid
Post by SpotlightKid » Fri Dec 01, 2017 12:25 am
Allright, I'll wait, until this more mature and documented. :)
jickster
Post by jickster » Fri Dec 01, 2017 4:57 pm
You'll be waiting awhile for it to be documented.
The hallmark of open source projects is lack of documentation. I'm not joking.
Furthermore, it's not about documentation. As I mentioned, you have to provide a port for your own OS/HW combination.
SpotlightKid
Post by SpotlightKid » Fri Dec 01, 2017 5:03 pm
The question remains then, how were these compiled:
    standard: v1.9.3-72-gbb047558 (latest) ; v1.9.3 ; v1.9.2 ; v1.9.1 ; v1.9 ; v1.8.7 ;
    double FP: v1.9.3-72-gbb047558 (latest) ; v1.9.3 ; v1.9.2 ;
    threading: v1.9.3-72-gbb047558 (latest) ; v1.9.3 ; v1.9.2 ;
    double FP + threading: v1.9.3-72-gbb047558 (latest) ; v1.9.3 ; v1.9.2 ;
    network: v1.9.3-72-gbb047558 (latest) ; v1.9.3 ; v1.9.2 ; v1.9.1 ; v1.9 ; v1.8.7 ;
jickster
Post by jickster » Fri Dec 01, 2017 5:27 pm
Have you verified the threading build is actually multithreaded?
It could be that there's just emtpy stubs for the threading API.
