Compilation and RAM usage FAQ
jickster
Post by jickster » Fri Dec 08, 2017 3:20 pm
Conceptually, why does a large script run out of RAM when it is compiled?
What is the relative ratio of usage of RAM (heap vs stack)?
Codewise, which part of the code causes RAM to be depleted (and is it heap vs stack)?
jickster
Re: Compilation and RAM usage FAQ
Post by jickster » Fri Dec 08, 2017 3:26 pm
If I run one line (or block) at a time of a `.py` via the REPL API (as in pyexec.c:pyexec_raw_repl()), will I eliminate the issue of running out of RAM during compilation?
i.e. for N lines in a `.py` file, will my peak RAM usage during compilation be more, less, or same if I feed in one line at a time vs compile the entire N lines at once?
I understand it'll be much slower but let's say I was running out of RAM during compilation and didn't care about speed.
jickster
Post by jickster » Fri Dec 08, 2017 3:32 pm
If I compile the N lines separately, is it possible to stitch together the resulting bytecode returned by
mp_raw_code_t *rc = mp_compile_to_raw_code(parse_tree, source_file, emit_opt, is_repl);
into one mp_raw_code_t ?
chrismas9
Post by chrismas9 » Fri Dec 08, 2017 10:57 pm
It's probably easier to pre-compile to mpy file on a PC
jickster
Post by jickster » Fri Dec 08, 2017 11:26 pm
chrismas9 wrote:It's probably easier to pre-compile to mpy file on a PC
It is but in some cases it’s not an option
Sent from my iPhone using Tapatalk
Post by pythoncoder » Sat Dec 09, 2017 7:19 am
@jickster Have you read http://docs.micropython.org/en/latest/p ... ained.html? In particular the section on the heap.
jickster
Post by jickster » Sat Dec 09, 2017 1:59 pm
pythoncoder wrote:@jickster Have you read http://docs.micropython.org/en/latest/p ... ained.html? In particular the section on the heap.
Which sections answer my questions?
Post by deshipu » Sat Dec 09, 2017 5:15 pm
Read them then you will know.
jickster
Post by jickster » Sat Dec 09, 2017 7:19 pm
Where’s the answer to this?
jickster wrote:If I compile the N lines separately, is it possible to stitch together the resulting bytecode returned by
jickster
Post by jickster » Sat Dec 09, 2017 7:20 pm
Which section gives the answer to this question
