MY9221 - Grove LED Bar
mcauser
Post by mcauser » Thu Jan 25, 2018 3:57 pm
Ported my MicroPython MY9221 library to the micro:bit.
https://github.com/mcauser/microbit-my9221
https://github.com/mcauser/micropython-my9221
from my9221 import MY9221
ledbar = MY9221(di=Pin(4), dcki=Pin(5))
ledbar.level(4, 0x0F)
ledbar.bits(0b1010101010)
ledbar.bytes(bytearray([0,1,3,7,15,31,63,127,255,255]))
BruinBear
Re: MY9221 - Grove LED Bar
Post by BruinBear » Tue Jul 17, 2018 10:29 pm
Very nice! Thanks for that.
mcauser
Post by mcauser » Tue Jul 17, 2018 11:50 pm
If you're interested in the Grove modules, Seeed now have a Grove shield for micro:bit with an edge connector and breaks out 4 ports:
https://www.seeedstudio.com/Grove-Shiel ... -3083.html
BruinBear
Post by BruinBear » Wed Jul 18, 2018 9:09 pm
I know - I have one! They have produced a MakeCode package for the "Grove Inventor's Kit for micro:bit". The package includes support for the non-trivial devices in that Kit (Ultrasonic, 4x7-seg display and Gesture sensor). Very good stuff.
Would be good to couple the Grove LED bar with the Grove ultrasonic.
Unfortunately, the Grove LED Bar is not in the Kit so there are no MakeCode blocks for it. Likewise, I can't find a micropython module for the Grove ultrasonic. It uses "single pin mode" and Fizban's HCSR04 module uses separate trig and echo pins.
mcauser
Post by mcauser » Wed Jul 18, 2018 11:38 pm
BruinBear
Post by BruinBear » Thu Jul 19, 2018 8:23 am
Nice!
You just need to work on the Grove ultrasonic module now :D
rhubarbdog
Post by rhubarbdog » Sun Dec 02, 2018 6:42 am
I've downloaded tm1637.py . It's pretty big. I'm able to execute a 4 line program
from microbit import *
from tm1637 import TM1637
tm = TM1637(clk = pin1, dio = pin2)
tm.show('COOL')
But a simple thermometer using a tmp36 , a device which only uses microbit.read_analog()
I get memory errors.
