lcd160cr.py Recipe for target failed
Jacob_Beningo
Post by Jacob_Beningo » Mon Jan 29, 2018 4:30 pm
I'm moving to the latest kernel build 1.9.3 but seem to be unable to successfully build for an STM32 board. I am getting the following error:
MPY modules/lcd160cr.py
File "modules/lcd160cr.py", line 1
SyntaxError: invalid syntax
../../py/mkrules.mk:115: recipe for target 'build-PYBV3/frozen_mpy/lcd160cr.mpy' failed
make: *** [build-PYBV3/frozen_mpy/lcd160cr.mpy] Error 1
I'm following the directions to make mpy-cross first using:
make mpy-cross
from the root repository directory as described at https://github.com/micropython/micropyt ... 6a44d44918.
I then am running from the STM32 directory
make BOARD=PYBV3
Is there something obvious that I am overlooking to compile the latest kernel?
Thanks!
Re: lcd160cr.py Recipe for target failed
Post by Roberthh » Mon Jan 29, 2018 5:55 pm
Are you sure you have an Pyboard Version 0.3?
And no, you do not have to call mpy-cross manually. That's done by the Makefile. All sources to be included in flash have to be in the modules subdirectory of STM32
