W5500 isconnected() False
ulne
Post by ulne » Tue Jan 30, 2018 11:11 am
I want to use the Pyboard 1.1
with a W5500 Board like this
(https://www.aliexpress.com/item/W5500-E ... 20397.html)
I connect the W5500 like this:
MOSI connected to X8
MISO connected to X7
SCLK connected to X6
nSS connected to X5
nRESET connected to X4
The Firmware ist the newest for network
The Pythoncode:
nic = network.WIZNET5K(pyb.SPI(1), pyb.Pin.board.X5, pyb.Pin.board.X4)
print(nic.isconnected())
The export ist:
False
Thank you
cefn
Re: W5500 do not work
Post by cefn » Thu Feb 01, 2018 1:17 am
Hello and welcome to the Micropython Forum.
Unfortunately there's not much information in your post, describing for example...
* what you did in detail
* what you expected to happen
* what actually happened
* how you attempted to fix it
Sharing only "It don't work" makes it very hard for the community to identify what issue you are experiencing or resolve it.
I have often referred people to this reference document, which explains what makes a good bug report https://www.chiark.greenend.org.uk/~sgtatham/bugs.html
ulne
Re: W5500 isconnected() False
Post by ulne » Thu Feb 01, 2018 6:38 am
nSS connected to X5
The Pythoncode:
The export ist:
False
Do the pyboard work with the W5500?
Thank you
Topaazy
Post by Topaazy » Mon Feb 12, 2018 12:52 pm
Hey ulne,check out this topic.
I was looking for solutions to my problem on the forum, I came across yours.
May help. ;)
http://docs.micropython.org/en/v1.8.7/p ... twork.html
Regards Topazy.
ulne
Post by ulne » Tue Feb 13, 2018 9:31 am
Thank you Topaazy
I have connect my W5500 like your link
nSS connected to X5 SCS on the W5500 Board
nRESET connected to X4 RST on the W5500 Board
like the class WIZNET5K
My Programm:
print(nic.ifconfig())
returns:
('0.0.0.0', '255.255.255.255', '0.0.0.0', '8.8.8.8')
False
Is the problem the inverted RESET and SS ??
best regards
