GPIO12 (MTDI) is used as a bootstrapping pin to select output voltage of an internal regulator which powers the flash chip (VDD_SDIO).
This pin has an internal pulldown so if left unconnected it will read low at reset (selecting default 3.3V operation).
When adding a pullup to this pin for SD card operation, consider the following:
- For boards which don't use the internal regulator (VDD_SDIO) to power the flash, GPIO12 can be pulled high.
- For boards which use 1.8V flash chip (e.g. WROVER), GPIO12 needs to be pulled high at reset. This is fully compatible with SD card operation.
- On boards which use the internal regulator and a 3.3V flash chip (e.g. ESP-WROOM-32), GPIO12 must be low at reset. This is incompatible with SD card operation.
In most cases,
external pullup can be omitted and an internal pullup can be enabled using a
gpio_pullup_en(GPIO_NUM_12); call.
This is handled by SDCard driver.
Another option is to burn the flash voltage selection efuses.
This will permanently select 3.3V output voltage for the internal regulator, and GPIO12 will not be used as a bootstrapping pin.
Then it is safe to connect a pullup resistor to GPIO12.
This option is suggested for production use.
<esp-idf_path>/components/esptool_py/esptool/espefuse.py set_flash_voltage 3.3V
You can also use sdcard in
1-line SD mode in which case GPIO12 (MTDI) is not used.
