microSD card - clarification
philwilkinson40
Post by philwilkinson40 » Tue Feb 13, 2018 4:51 am
Please can someone clarify the correct approach/best approach to interact with a microSD card with a ESP8266.
My use case is to save sensor data as files to a microSD card. Periodically, connecting to wifi and sending the data files back to a remote MQTT broker.
I am using a Wemos D1Mini and have a shield attached. The SPI connections are standard. The latest version of micropython 1.9.3 is installed. The microSD card is a decent brand, has been checked as OK and has been formatted.
-On initial boot the microSD card is not added to the filesystem; of course.
-Adding the MicroPython driver for SD cards using SPI bus returns an error at the unmount function when trying the suggested sample code
import machine, sdcard, os
sd = sdcard.SDCard(machine.SPI(1), machine.Pin(15))
os.umount()
os.VfsFat(sd, "")
os.listdir()
TypeError: function takes 1 positional arguments but 0 were given
the sdtest.py file that comes with the driver uses the PYB module so I assumed it was not suitable.
the excellent esp8266 tutorial also fails at the same point of unmounting.
The micropython UOS module for the ESP8266 does not contain mount/unmount functions so I am not sure what to do. Should I be creating a SPI object ?
Re: microSD card - clarification
Post by deshipu » Tue Feb 13, 2018 8:50 am
That's just the normal practice of MicroPython changing the API without updating the documentation or examples. Better get used to it.
philwilkinson40
Post by philwilkinson40 » Tue Feb 13, 2018 1:51 pm
:D ok thanks, i thought it must be the usual technical gap in my knowledge! I still have much to learn about the micropython project...
Post by OutoftheBOTS_ » Tue Feb 13, 2018 7:49 pm
Micropython is very new and fast developing. The docs definitely trail far behind the new development that happens everyday.
But on the up side the authors of the new development r often on this forum and can answer your questions.
I haven't used this exact library but looking at the error it is expecting a argument to be given at os.umount(), the libiary that I use for the ESP32 you can pass True and it will mount the SD card and change directories to it so maybe try os.umount(True) and see what happens :)
philwilkinson40
Post by philwilkinson40 » Wed Feb 14, 2018 12:44 pm
sadly os.unmount(True) returns the old
OSError: [Errno 22] EINVAL
...invalid argument!
I have also tried following the Adafruit tutorial and that also fails on
>>> vfs=os.VfsFat(sd, "")
TypeError: function takes 1 positional arguments but 2 were given
removing the second argument "" removes the error, but of course that was the argument that was the path on the filesystem to mount the card, so that did nothing either.
Does anyone have any experience on using SDs on ESP8266? Ideas of other approaches?
JDRBoston
Post by JDRBoston » Mon Feb 19, 2018 10:03 pm
Hi Phil,
I'm working on a similar project - I am trying to use the Huzzah ESP8266 to collect data from a BME280 breakout board and an LDR, get a time-stamp from a RTC, and write the information to a SD card. I'm not sure whether this helps, but I have been able to mount an SD card using the following:
def sdmount():
os.umount('/')
vfs = os.VfsFat(sd)
os.mount(vfs, '/sd')
return
I'm using the esp8266-20170823-v1.9.2 build.
philwilkinson40
Post by philwilkinson40 » Fri Feb 23, 2018 8:14 am
great thanks @JDRBoston, that worked!
so, just to summarise for those visiting this thread later.
I was using a Wemos D1 Mini uSD shield shown below and the SD driver from the micropython github repository.
this allows
>>> from machine import Pin, SPI
>>> import os
>>> import sdcard
>>> sd = sdcard.SDCard(SPI(1), Pin(15))
>>> os.umount('/')
>>> vfs=os.VfsFat(sd)
>>> os.listdir()
['sd']
from which point you can open and write files as per usual to the uSD card. Don't forget to use the full path.
>>> o = open('/sd/test.txt', 'w')
>>> o.write('Smurf')
5
>>> o.close()
>>> p = open('/sd/test.txt', 'r')
>>> p.read()
'Smurf'
>>> p.close()
JDRBoston
Post by JDRBoston » Sun Mar 18, 2018 8:28 pm
Hi Phil,
I am glad that it helped! Thank you for the example on how to write a file into the sd directory and then read it.
Do you know how one can get access to libraries and run micropython code that has been transferred to the sd card? In my case, I would like to run a program that will access libraries that will allow me to connect to i2c-sensors, get the data, and then store it on the sd card. After formatting the sd card, I backed out and tried to use ampy to transfer the files to the esp8266 but this was not successful - I don't think that ampy likes working with the esp8266 after it has setup the sd directory. Also, I tried loading a py file containing the python program onto the sd card using my computer and then getting it to run after I put the sd card in the esp8266 and setup the sd card but I was unsuccessful. The esp sees the py file but I could not load it as a library and execute the program.
I would appreciate any advice. Thank you, Jay
Name of file saved via computer onto sd card:
led_2.py
File:
# LED functions
# pin 0 is the big red LED
def blink(durON,durOFF,n):
p0 = Pin(0, Pin.OUT)
for i in range(n):
p0.off()
time.sleep(durON)
p0.on()
time.sleep(durOFF)
return
REPL input/output after the sdcard has been loaded using the method described in the thread above:
>>> o=open('/sd/led_2.py','r')
>>> o.read()
'# LED functions\n#\n# pin 0 is the big red LED\n\n\ndef blink(durON,durOFF,n):\n\tfrom machine import Pin\n\timport time\n\tp0 = Pin(0, Pin.OUT)\n\tfor i in range(n):\n \tp0.off()\n \ttime.sleep(durON)\n \tp0.on()\n \ttime.sleep(durOFF)\n return\n\n\t\n'
>>> import led_2
ImportError: no module named 'led_2'
>>> import /sd/led_2
File "<stdin>", line 1
SyntaxError: invalid syntax
Post by dhylands » Sun Mar 18, 2018 11:50 pm
In MicroPython (and CPython) when you use import it searches the directories listed in the sys.path variable to find the modules.
So if you do something like
import sys
sys.path.append('/sd')
then you should be able to use
import led_2
and it will find led_2.py in the /sd directory.
JDRBoston
Post by JDRBoston » Mon Mar 19, 2018 10:50 am
This worked GREAT Dave - thank you, very much! Best wishes, Jay
