"... object must have mp_obj_base_t" - what about mp_obj_namedtuple_type_t
jickster
Post by jickster » Mon Mar 26, 2018 9:34 pm
I've been creating types and I've followed this rule
// This mp_obj_type_t struct is a concrete MicroPython object which holds info
// about a type.  See below for actual definition of the struct.
typedef struct _mp_obj_type_t mp_obj_type_t;
// Anything that wants to be a concrete MicroPython object must have mp_obj_base_t
// as its first member (small ints, qstr objs and inline floats are not concrete).
struct _mp_obj_base_t {
    const mp_obj_type_t *type MICROPY_OBJ_BASE_ALIGNMENT;
typedef struct _mp_obj_base_t mp_obj_base_t;
and everything has worked out.
So then why are there native types that do not follow this rule?
#if MICROPY_PY_COLLECTIONS
typedef struct _mp_obj_namedtuple_type_t {
    mp_obj_type_t base;
    size_t n_fields;
    qstr fields[];
} mp_obj_namedtuple_type_t;
I understand that the only difference between
mp_obj_type_t
and
mp_obj_base_t
is that
mp_obj_base_t
is a struct containing a
mp_obj_type_t *
So why is it ok to use mp_obj_type_t directly?
Re: "... object must have mp_obj_base_t" - what about mp_obj_namedtuple_type_t
Post by dhylands » Mon Mar 26, 2018 9:42 pm
I'm going to guess that it's just an oversight, and that it really should be an mp_obj_base_t.
The reason it happens to work is because mp_obj_base_t and mp_obj_type_t are both the same size.
mp_obj_base_t includes an alignment directive that the namedtuple is lacking, so declaring a static namedtuple might be problematic on say a 16-bit architecture like the pic16bit port.
jickster
Post by jickster » Tue Mar 27, 2018 2:11 pm
They're not the same size. Nowhere near.
mp_obj_type_t is a struct containing many elements
struct _mp_obj_type_t {
    // A type is an object so must start with this entry, which points to mp_type_type.
    mp_obj_base_t base;
    // The name of this type.
    qstr name;
    // Corresponds to __repr__ and __str__ special methods.
    mp_print_fun_t print;
mp_obj_base_t is a struct containing one item: a pointer to mp_obj_type_t
Post by dhylands » Tue Mar 27, 2018 3:47 pm
My bad. I wasn't looking at the right thing.
The named tuple type has an mp_obj_type_t as its first member, and mp_obj_type_t has the base type as its first member, so the first 4 bytes of a named tuple is still a pointer to the base type.
I'd have to look at a bunch more of the code to see why it was done this way instead of the way the other native types were done.
