Driver for LCD display Nokia 5110
krzysiu
Re: Driver for LCD display Nokia 5110
Post by krzysiu » Sat Aug 12, 2017 4:33 pm
I trying to use your exemple but my display not working ?? i find other example but not with micropython board.
sommeone can help me please. ?? :P
krzysiu
Post by krzysiu » Sun Aug 13, 2017 6:12 am
sorry my first post are posted so fast :oops:
I connected my micro python to LCD Screen like this :
RST =>Y4
CE => Y5
DC => Y3
LIGHT =>Y2
PWR =>Y1
CLK => Y6
DCIN => Y7
And i use this exemple :
https://github.com/mbirth/wipy-upcd8544
it not work :cry:
can you help me please.... :)
Post by deshipu » Sun Aug 13, 2017 10:23 am
Dear krzysiu, how are you trying that example, what are you doing exactly, what are your connection and how it is not working — what results do you get? Also, how do you imagine we can help you here?
mcauser
Post by mcauser » Mon Aug 14, 2017 2:29 am
I wrote a library for the Nokia 5110's PCD8544 lcd driver: https://github.com/mcauser/micropython-pcd8544
I have it working with an ESP8266, but changing it to work with the pyboard should be straight forward.
See the readme for examples.
krzysiu
Post by krzysiu » Mon Aug 14, 2017 2:22 pm
Thanks for your responses,
@ deshipu, I think it's just connection probleme, with LCD board and micropython... @mcauser, i see your readme, and your code where your decribe how to connect on micropython (but i'm not very easy in english :oops: :roll: ).
this week i try it another... and tell you my results or not :D
it is not possible to add photos in this forum ?
Best regards
Krzysiu
Post by pythoncoder » Tue Aug 15, 2017 5:29 am
krzysiu wrote:...it is not possible to add photos in this forum ?...
Yes, but only after a new user has posted a few times. This is to protect against spambots.
krzysiu
Post by krzysiu » Tue Aug 15, 2017 4:01 pm
I try to explain you exactly my connection:
LCD Nokia <=> Micropython (Y Side)
RST <=> Y4
CE <=> Y5
DC <=> Y3
Din <=> Y7
Clk <=> Y6
Vcc <=> Y1
BL <=> Y2
Gnd <=> Gnd
i think Vcc - Y1 is a mistake ?
Vcc - 3,3volt or 5volt is correct ? ( i try it but not work )
BL = Back Ligth (?), must be connected to 3,3 volt too ?
I am sorry for basic question, but i am just starting use micropython, i am only a developper... :oops:
my code :
from machine import SPI, Pin
import pcd8544
# WiPy (on Exp board, SD and User-LED jumper have to be removed!)
#SPI    = machine.SPI(0)   # GP14 (CLK) + GP16 (MOSI->DIN), User-LED jumper removed!
#RST    = machine.Pin('GP24')
#CE     = machine.Pin('GP12')
#DC     = machine.Pin('GP22')
#LIGHT  = machine.Pin('GP23')
# PWR    = directly from 3V3 pin of the WiPy
#SPI    = pyb.SPI(1)
#RST    = pyb.Pin('Y4')
#CE     = pyb.Pin('Y5')
#DC     = pyb.Pin('Y3')
#LIGHT  = pyb.Pin('Y2')
#PWR    = pyb.Pin('Y1')
spi = pyb.SPI(1)
spi.init(baudrate=8000000, polarity=0, phase=0)
cs = pyb.Pin('Y5')#Pin(2)
dc = pyb.Pin('Y3')#Pin(15)
rst = pyb.Pin('Y4')#Pin(0)
# backlight on
bl = pyb.Pin('Y2',pyb.Pin.OUT, value=1) #Pin(12, Pin.OUT, value=1)
lcd = pcd8544.PCD8544(spi, cs, dc, rst)
# test pattern (50% on)
lcd.data(bytearray([0x55, 0xAA] * 42 * 6))
Thanks for your help ...
mcauser
Post by mcauser » Tue Aug 15, 2017 9:07 pm
Change Din <=> Y7 to Din <=> Y8.
Y7 = miso
Y8 = mosi
vcc should be connected to 3v3. This is how you power the display.
BL is the led backlight behind the display. You can either connect it to a GPIO pin and control it with software, or connect it to 3v3 to have it always lit. The display is readable without the backlight, so it's optional.
Try calling lcd.reset() and lcd.init().
krzysiu
Post by krzysiu » Wed Aug 16, 2017 1:08 pm
Ok,
i change Din
I look at my code, I think the problem must come from there. This time it seems to work better the BL reacts.
When i test lcd.init () the program stop
from pyb import LED
from pyb import SPI #, Pin
import upcd8544 #pcd8544
#SPI    = pyb.SPI(1)
RST    = pyb.Pin('Y4')
CE     = pyb.Pin('Y5')
DC     = pyb.Pin('Y3')
PWR    = pyb.Pin('Y1')
#spi = pyb.SPI(1)
#spi.init(baudrate=8000000, polarity=0, phase=0)
spi = SPI(1,SPI.MASTER,baudrate=8000000, polarity=0, phase=0)
## backlight on
#lcd = upcd8544.PCD8544(spi, cs, dc, rst)
lcd = upcd8544.PCD8544(spi, RST, CE, DC, LIGHT)
lcd.reset()
lcd.init()
#lcd.data(bytearray([0x55, 0xAA] * 42 * 6))
led = LED(4) # for testing code
led.on()
