accessing REPL via pyserial
v923z
Re: accessing REPL via pyserial
Post by v923z » Thu May 10, 2018 7:35 pm
dhylands wrote:
Wed May 09, 2018 4:36 pm
In the REPL, each statement you execute is evaluated and if the return value from the statement is not equal to None, then the result is printed. Consider the following:
>>> def foo():
...     print('Hey there')
...     return 42
>>> foo()
Hey there
42
>>> def foo2():
...     print('Another print')
...     return None
>>> foo2()
Another print
>>> def foo3():
...     print('foo3')
>>> foo3()
foo3
>>> def foo4():
...     print('Before 3 * 3')
...     3 * 3
...     print('After 3 * 3')
...     return 42
>>> foo4()
Before 3 * 3
After 3 * 3
42
An function which doesn't return anything winds up returning None
But if you try to run this this through pybooard.py, then this no longer holds. Here is an example, called test.py:
def f():
    print('in f()')
    return 12
f()
def g():
    return 13
g()
print('print g: ', g())
and if I do this:
python pyboard.py test.py
then I get this:
$ python pyboard.py test.py
in f()
print g:  13
Neither 12, nor 13 is printed, while these numbers were in fact returned. I understand what you are saying, and it is clear that something that returns None is not printed. But if the function does return something, this still doesn't guarantee that the result is printed. It depends on the context.
Post by dhylands » Thu May 10, 2018 7:52 pm
The reason that you don't see 12 or 13 printed when running through pyboard.py is that you're NOT running through the REPL.
What pyboard.py does is like running a script. You'll see the exact same behavior when running your test.py script under python3:
794 >python3 test.py
in f()
print g:  13
Using pyboard.py:
795 >python ../../tools/pyboard.py test.py
in f()
print g:  13
Similarly, if I were to instead paste the contents of test.py into a python3 REPL or a MicroPython REPL, I would see:
799 >python3
Python 3.6.5 (default, Apr  1 2018, 05:46:30)
[GCC 7.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> def f():
...     print('in f()')
...     return 12
>>> f()
in f()
12
>>> def g():
...     return 13
>>> g()
13
print g:  13
When running python code from a script, the only thing that's printed are actual print statements (or other things which write data to the same place print does).
REPL is short for "Read Eval Print Loop" and the print portion is what's causing the output of each line to printed.
v923z
Post by v923z » Sun May 13, 2018 5:36 pm
OK, then it is probably a question of what is "invoking" the REPL in the first place. pyboard does not, but any serial terminal does. I see that this issue is probably not related to the board as such, but to the software on the computer.
Post by dhylands » Mon May 14, 2018 4:50 pm
The REPL is run by MicroPython after main.py returns.
For the pyboard, which uses the stm32 port, this is where boot.py is executed:
https://github.com/micropython/micropyt ... #L628-L642
This is where main.py is executed:
https://github.com/micropython/micropyt ... #L687-L705
And this is where the REPL is executed:
https://github.com/micropython/micropyt ... #L707-L719
