nvram json read write for esp32 & pyboard
devnull
Post by devnull » Mon Jun 04, 2018 2:54 am
Based on the info gathered from here ( viewtopic.php?f=6&t=953 ) I have created a json read / write module, hopefully someone else will find it useful.
jram.py
import json
from sys import platform
if platform == 'pyboard':
  import stm, uctypes
  class JRAM(object):
    BKPSRAM = 0x40024000
    def __init__(self):
      stm.mem32[stm.RCC + stm.RCC_APB1ENR] |= 0x10000000    # PWREN bit
      stm.mem32[stm.PWR + stm.PWR_CR] |= 0x100              # Set the DBP bit in the PWR power control register
      stm.mem32[stm.RCC +stm.RCC_AHB1ENR]|= 0x40000         # enable BKPSRAMEN
      stm.mem32[stm.PWR + stm.PWR_CSR] |= 0x200             # BRE backup register enable bit
    def __getitem__(self, idx):
      assert idx >= 0 and idx <= 0x3ff, "Index must be between 0 and 1023"
      return stm.mem32[self.BKPSRAM + idx * 4]
    def __setitem__(self, idx, val):
      stm.mem32[self.BKPSRAM + idx * 4] = val
    def get_bytearray(self):
      return uctypes.bytearray_at(self.BKPSRAM, 4096)
    def clr(self):
      self.put({})
      return self.get()
    def get(self):
      ba = self.get_bytearray()
        return json.loads(bytes(ba[4:4+self[0]]).decode("utf-8"))
      except:
        return self.clr()
    def put(self,a):
      z = json.dumps(a).encode('utf8')
      self[0] = len(z)
      ba[4: 4+len(z)] = z
elif platform.startswith('esp32'):
  class JRAM():
    ## Non Volatile JSON
    def get(self):
      try:return json.loads(rtc.memory().decode('ascii'))
      except: return {}
    def put(self,dic):
      rtc.memory(json.dumps(dic))
    def clr(self):
      put({})
      return get()
## usage
# from jram import JRAM as nvr
# nvr().clr()
# nvr().put({'elephants': 9, 'rats': 77, 'dogs': 99, 'zoo': 100})
# nvr().get()
LisaM
Re: nvram json read write for esp32 & pyboard
Post by LisaM » Thu Aug 09, 2018 4:31 pm
This doesn't work for the ESP32, the RTC memory is cleared during startup (and therefor also after a machine.reset() ).. :(
