Read 2 or more pins as binary bits
devnull
Post by devnull » Mon Jun 04, 2018 5:29 am
Is there a simple was to combine 2 or more pins together as a virtual port and read as binary bits ?
I am using a PIC micro to do some things outside of micropython and one of the things it will do is to output a 2 bit value (0 to 3) which I would like to read in micropython.
Re: Read 2 or more pins as binary bits
Post by OutoftheBOTS_ » Mon Jun 04, 2018 7:15 am
I would assume that you would do something like this
two_bits = pin1.value() <<1 | pin2.value()
Post by pythoncoder » Mon Jun 04, 2018 10:55 am
That would be my approach.
If speed is vital it is possible to access multi-bit I/O but it isn't for the faint-hearted; it certainly needs a study of the chip datasheet. An example may be found here in the file TFT_io.py.
