remove whitespace while reading file
devnull
Post by devnull » Tue Jun 12, 2018 8:03 am
      self.chunk = 2048
      with open(self.fdir+req['path'], 'rb') as html:
        head = self.head(req['path'])
        chunk = head + html.read(self.chunk - len(head))
        while chunk:
          res.sendall(chunk)
          chunk = html.read(self.chunk)
        res.close()
It tried strip() but that does not work, how can I compress the read (html) file by removing whitespaces and carriage returns before sending ?
Re: remove whitespace while reading file
Post by Roberthh » Tue Jun 12, 2018 8:24 am
e.g.
"".join(chunk.split())
devnull
Post by devnull » Tue Jun 12, 2018 9:51 am
Thanks, that results in:
Error: join expects a list of str/bytes objects consistent with self object
Also tried:
"".join(chunk.decode().split()).encode()
By that's no good either !
Post by Roberthh » Tue Jun 12, 2018 11:09 am
if chunk is a bytes object, you may need:
b"".join(chunk.split())
Post by pythoncoder » Wed Jun 13, 2018 7:10 am
The unicode support in Python 3 requires constant attention to detail regarding the difference between bytes (and bytearray) objects and strings. It still regularly catches me out...
