Micropython on Odroid Go?
holger
Post by holger » Tue Jul 10, 2018 1:49 pm
Has anyone tried Micropython on this nice Gear?
https://www.hardkernel.com/main/products...2875062626
Holger
Re: Micropython on Odroid Go?
Post by dhylands » Tue Jul 10, 2018 4:11 pm
The link doesn't work for me. But it looks like they all run linux, so you'd be using the unix port of Micropython.
loboris
Post by loboris » Tue Jul 10, 2018 6:26 pm
It is a ESP32 board (based on ESP32-WROVER) wich should run MicroPython without issues.
The correct link is ODROID-GO
Post by dhylands » Tue Jul 10, 2018 7:03 pm
Yes that definitely looks sweet.
deshipu
Post by deshipu » Tue Jul 10, 2018 10:00 pm
I have tried both the loboris and the official ports, and they work fine. The loboris port can make use of the additional RAM chip, which is very nice.
I'm working on porting my game library to it, so that all the games made for µGame will also work on ODROID GO.
jedie
Post by jedie » Tue Oct 02, 2018 3:32 pm
Can you be more specific about what you flashed?
Because i used from https://github.com/loboris/MicroPython_ ... sRAM_LoBo/ the esp32_psram_all and flashed it with:
MicroPython_ESP32_psRAM_LoBo/MicroPython_BUILD/firmware/esp32_psram_all$ ../flash.sh
The REPL works. But i get errors like:
OSError: [Errno 19] ENODEV
I created https://github.com/loboris/MicroPython_ ... issues/221 for this.
Any idea?
mattyt
Post by mattyt » Thu Oct 04, 2018 4:11 am
Just FYI; Mainline MicroPython gained support for ESP32 PSRAM with 1.9.4. Like the Loboris port you need to download the appropriate binary.
jedie
Post by jedie » Thu Oct 04, 2018 7:09 am
Thanks. I currently use mainline esp32spiram-20181004-v1.9.4-623-g34af10d2e.bin
