New Bosch BME280 temperature, humidity, pressure sensor library
Hasenradball
Re: New Bosch BME280 temperature, humidity, pressure sensor library
Post by Hasenradball » Tue Jul 09, 2019 6:51 am
Hi Robert,
Thanks for you support!
Just one question, please.
What is the benefit of the Property functionality?
Best regards
Frank
Post by Roberthh » Tue Jul 09, 2019 7:34 am
That's up to you. Properties can be use to get, set and delete data of a class. For getting, there is usually almost no difference to using a function call notation. The only difference in the actual case would be writing 'bme.values()' instead of 'bme.values'. setting or deleting makes a difference, because a setter would also be transformed into a function call, than can do rather complex operations, while still looking like a simple assignment by the callee. Still that could be done with a class method call, and you may call that 'syntactic sugar'.
For the actual BME280 the benefit of using properties is minor.
Hasenradball
Post by Hasenradball » Tue Jul 09, 2019 8:33 am
I tested yesterday the property call and I got an error.
Maybe my call was wrong.
But I will check it angain today.
Thanks a lot....
