Sparkfun ESP32 board
Darius
Post by Darius » Wed Aug 08, 2018 11:23 pm
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:QIO, clock div:2
load:0x3fff0018,len:4
load:0x22b2caaf,len:994132516
1162 mmu set 00010000, pos 00010000
1162 mmu set 00020000, pos 00020000
1162 mmu set 00030000, pos 00030000
1162 mmu set 00040000, pos 00040000
1162 mmu set 00050000, pos 00050000
1162 mmu set 00060000, pos 00060000
1162 mmu set 00070000, pos 00070000
1162 mmu set 00080000, pos 00080000
1162 mmu set 00090000, pos 00090000
ets Jun 8 2016 00:22:57
I am trying MicroPython on SparkFun's ESP32 'Thing' but it crashes after flashing..
With esp32-20180808-v1.9.4-443-gc1c798fbc.bin ->
With esp32-20180511-v1.9.4.bin ->
load:0x0008e0c4,len:25745276
I did a flash erase & write as well but no change.
Capstan
Re: Sparkfun ESP32 board
Post by Capstan » Mon Aug 13, 2018 10:31 pm
How are you flashing it?
Darius
Post by Darius » Tue Aug 14, 2018 1:16 am
I flashed it like this..
esptool.py --chip esp32 --port /dev/cu.usbserial-DN02MPA4 write_flash -z 0x1000 ~/Downloads/esp32-20180808-v1.9.4-443-gc1c798fbc.bin
Interestingly I subsequently tried an Espruino image like so..
esptool.py --chip esp32 --port /dev/cu.usbserial-DN02MPA4 write_flash -z 0x1000 ~/Downloads/esp32-20180511-v1.9.4.bin
--chip esp32                                \
        --port /dev/ttyUSB0                         \
        --baud 921600                               \
        --after hard_reset write_flash              \
        -z                                          \
        --flash_mode dio                            \
        --flash_freq 40m                            \
        --flash_size detect                         \
        0x1000 bootloader.bin                       \
        0x8000 partitions_espruino.bin              \
        0x10000 espruino_esp32.bin
which crashed.. but then I re-did the MicroPython image like so and it worked?!
esptool.py --chip esp32                                \
        --port /dev/cu.usbserial-DN02MPA4                         \
        --baud 921600                               \
        -z                                          \
        --flash_mode dio                            \
        --flash_freq 40m                            \
        0x1000 esp32-20180808-v1.9.4-44
Capstan
Post by Capstan » Tue Aug 14, 2018 3:16 am
So it is working for you? What cued you to change the flashing options to those particular values?
Darius
Post by Darius » Tue Aug 14, 2018 3:19 am
Yes it does work now, I should've updated my post.
As for why I changed - I saw that Espruino got a little further with different options so I tried those for MicroPython - sometimes even wild guesses pay off :)
I did wonder if the image had some settings my ESP32 board didn't like but image_info didn't show anything useful, eg..
[Maelstrom 12:49] ~ >esptool image_info ~/Downloads/esp32-20180808-v1.9.4-443-gc1c798fbc.bin
esptool.py v2.5.1-dev
WARNING: Suspicious segment 0xee, length 0
WARNING: Suspicious segment 0x0, length 16777216
A fatal error occurred: End of file reading segment 0x0, length 16777216 (actual length 1047432)
[Maelstrom 12:49] ~ >esptool image_info ~/Downloads/espruino_1v99_esp32.bin
A fatal error occurred: End of file reading segment 0x0, length 16777216 (actual length 1111544)
liudr
Post by liudr » Thu Aug 16, 2018 4:53 pm
You never posted what flashing command you used that caused your dev board to crash though. I bet the crashes were caused by the command. One needn't to do wild guesses. I have done a dozen or two flashes and everything it went correctly. I keep the command in a document. It's a good idea to log what command you use, especially when it is going very well and you thought nothing was going to break.
Here is the official firmware with flash command:
http://micropython.org/download#esp32
Darius
Post by Darius » Fri Aug 17, 2018 12:32 am
I posted it here viewtopic.php?p=29401#p29327
I did try a chip erase as well.
I re-ran that command and flashed it again and it worked, so.. I have no idea why it didn't work previously :-/
Post by pythoncoder » Fri Aug 17, 2018 4:37 am
...I keep the command in a document...
Even better is to keep the command in a script ;) Like these examples. That way I can run (for example) buildpyb. It detects the type of attached board, gets the latest code, builds it for the right target, and flashes it. With my senescent brain it saves no end of silly mistakes ;)
liudr
Post by liudr » Sat Aug 18, 2018 12:37 am
Thanks. I'll try and learn more scripting (maybe more docs to write about how to do scripting so I can read about it when I forget). It's really hard to remember things the way I used to.
Post by pythoncoder » Sat Aug 18, 2018 7:47 am
Tell me about it :( I script tasks to compensate for my increasingly lousy memory. And growing ineptitude like building code for the wrong target...
