How to check if a python module exists without importing it
HermannSW
Post by HermannSW » Sun Sep 16, 2018 12:34 am
This thread is very informative for different versions of Python:
https://stackoverflow.com/questions/140 ... porting-it
But the answers don't help for MicroPython, since neither v2 "imp" module nor v3 "importlib" module can be imported on MicroPython 1.9.4. What is the answer to the question for MicroPython?
jickster
Re: How to check if a python module exists without importing it
Post by jickster » Sun Sep 16, 2018 1:26 am
HermannSW wrote:This thread is very informative for different versions of Python:
The answer is it doesn’t exist.
Create an issue on github to create it.
deonis
Post by deonis » Sun Sep 16, 2018 4:00 am
You can use
help("modules")
or if you want more details for a specific module then you need to import and use simialr command to get details.
For example:
import sys
help(sys)
Post by pythoncoder » Sun Sep 16, 2018 5:53 am
@deonis help('modules') only lists those modules which are frozen as bytecode.
HermannSW
Post by HermannSW » Sun Sep 16, 2018 10:27 am
Thanks, done:
https://github.com/micropython/micropython/issues/4148
jickster
Post by jickster » Sun Sep 16, 2018 3:08 pm
deonis wrote:You can use
help("modules")
For example:
import sys
help(sys)
import-ing can have side-effects.
But yeah I was fundamentally wrong.
jickster
Post by jickster » Sun Sep 16, 2018 5:11 pm
Help(“modules”) shows: builtin, frozen string, frozen mpy.
It doesn’t show file-based .py or .mpy
 mp_help_add_from_map(list, &mp_builtin_module_map);
    #if MICROPY_MODULE_WEAK_LINKS
    mp_help_add_from_map(list, &mp_builtin_module_weak_links_map);
    #endif
    #if MICROPY_MODULE_FROZEN_STR
    extern const char mp_frozen_str_names[];
    mp_help_add_from_names(list, mp_frozen_str_names);
    #endif
    #if MICROPY_MODULE_FROZEN_MPY
    extern const char mp_frozen_mpy_names[];
    mp_help_add_from_names(list, mp_frozen_mpy_names);
    #endif
