large file support for 32-bit Embedded Linux - seek fails after 2GB
c_toth
Post by c_toth » Tue Oct 02, 2018 2:48 pm
I recently ran into a problem where the .seek() fails after 2147483647 (2GB) on Micropython 1.9.4 cross compiled for ARM intended for 32-bit embedded Linux. Script was tested using qemu-arm -cpu any
The file / hard drive addresses I have to access become bigger than the seek can handle and result in the following error:
File "hd_test.py", line 22, in <module>
OverflowError: overflow converting long int to machine word
Here's my code: (script takes one argument - full file / hard drive path)
#!/bin/env/python
import sys
import ubinascii
drive = sys.argv[1] #Complete path to the target HD
print("DEBUG - Max Int Size:",sys.maxsize) # this is the max native integer type for the platform we are on.
f = open(drive, mode="rb+")
except:
print("Error opening target for READ / WRITE.")
sys.exit()
f.seek(2147483647)
print(f.read(8))
f.seek(147483600,1) #1 = seek from currrent position
print(f.read(8))
f.seek(3147483647); #####Fails here: OverflowError: overflow converting long int to machine word <<<<<<<
data = f.read(4)
f.close();
jickster
Re: large file support for 32-bit Embedded Linux - seek fails after 2GB
Post by jickster » Tue Oct 02, 2018 4:46 pm
#!/bin/env/python
import sys
import ubinascii
except:
sys.exit()
f.seek(2147483647)
print(f.read(8))
print(f.read(8))
data = f.read(4)
f.close();
This is a known issue
STATIC mp_obj_t stream_seek(size_t n_args, const mp_obj_t *args) {
    struct mp_stream_seek_t seek_s;
    // TODO: Could be uint64
    seek_s.offset = mp_obj_get_int(args[1]);
    seek_s.whence = SEEK_SET;
The problem is that mp_obj_get_int() returns a mp_int_t which must be pointer size so if you compile as 32-bit, it'll be 32-bit.
mp_obj_get_int() translates from a Python integer, which can be arbitrarily large, to a machine word which can only be 32-bit if you compiled it as 32-bit because the ioctl function must be called which does not know of Python integer-objects.
c_toth
Post by c_toth » Tue Oct 02, 2018 4:50 pm
Is there any way around this?
jickster
Post by jickster » Tue Oct 02, 2018 4:54 pm
Split up your seeks() larger than abs(2^31-1) into multiple seeks.
c_toth
Post by c_toth » Tue Oct 02, 2018 5:01 pm
I already tried that and it worked for a while.. but then I got another error: (OSError: [Errno 22] EINVAL)
safeseek(96032801808,0)
print(f.read(16))
Debugging output:
Debug Seek from Start: 2147483647 x 44 + 1543556188
DEBUG-FromStartPos - Jump 2147483647
DEBUG-FromStartPos - Jump 4294967294
DEBUG-FromStartPos - Jump 6442450941
DEBUG-FromStartPos - Jump 8589934588
DEBUG-FromStartPos - Jump 10737418235
DEBUG-FromStartPos - Jump 12884901882
DEBUG-FromStartPos - Jump 15032385529
DEBUG-FromStartPos - Jump 17179869176
DEBUG-FromStartPos - Jump 19327352823
DEBUG-FromStartPos - Jump 21474836470
DEBUG-FromStartPos - Jump 23622320117
DEBUG-FromStartPos - Jump 25769803764
DEBUG-FromStartPos - Jump 27917287411
DEBUG-FromStartPos - Jump 30064771058
DEBUG-FromStartPos - Jump 32212254705
DEBUG-FromStartPos - Jump 34359738352
DEBUG-FromStartPos - Jump 36507221999
DEBUG-FromStartPos - Jump 38654705646
DEBUG-FromStartPos - Jump 40802189293
DEBUG-FromStartPos - Jump 42949672940
DEBUG-FromStartPos - Jump 45097156587
DEBUG-FromStartPos - Jump 47244640234
DEBUG-FromStartPos - Jump 49392123881
DEBUG-FromStartPos - Jump 51539607528
DEBUG-FromStartPos - Jump 53687091175
DEBUG-FromStartPos - Jump 55834574822
DEBUG-FromStartPos - Jump 57982058469
DEBUG-FromStartPos - Jump 60129542116
DEBUG-FromStartPos - Jump 62277025763
DEBUG-FromStartPos - Jump 64424509410
DEBUG-FromStartPos - Jump 66571993057
DEBUG-FromStartPos - Jump 68719476704
DEBUG-FromStartPos - Jump 70866960351
DEBUG-FromStartPos - Jump 73014443998
DEBUG-FromStartPos - Jump 75161927645
DEBUG-FromStartPos - Jump 77309411292
DEBUG-FromStartPos - Jump 79456894939
DEBUG-FromStartPos - Jump 81604378586
DEBUG-FromStartPos - Jump 83751862233
DEBUG-FromStartPos - Jump 85899345880
DEBUG-FromStartPos - Jump 88046829527
DEBUG-FromStartPos - Jump 90194313174
DEBUG-FromStartPos - Jump 92341796821
DEBUG-FromStartPos - Jump 94489280468
File "hdtest.py", line 150, in <module>
File "hdtest.py", line 72, in safeseek
pfalcon
Post by pfalcon » Tue Oct 02, 2018 5:12 pm
Yeah, I'm thinking about it from time to time, and figure that lately my assumed reply for this issue is that "for 64bit offsets we have 64-bit architecture support in MicroPython". Feel free to describe your usecase, but so far MicroPython's approach was that "for 32-bit systems, 4GB should be enough for everyone, for rest, we have 64-bit support". Changing that would involved nice, careful (as usual!) patches to introduce optional 64-bit stream offset support. And mind that such support depends on kernel, so wouldn't have to work on a random device (and if your choice is not random, it again perhaps could be towards a 64-bit system).
Awesome MicroPython list
jickster
Post by jickster » Tue Oct 02, 2018 5:17 pm
The binary architecture has nothing to do with the size of the flash drive you use.
jickster
Post by jickster » Tue Oct 02, 2018 6:21 pm
print(f.read(16))
Debugging output:
That's a Linux error not micropython.
