Writing to a local file is giving an error
analogdiode
Post by analogdiode » Fri Oct 12, 2018 4:42 pm
I am trying to write to a local file every 100ms, and after the program has run I expect to see a txt file with numbers 0 through 99 in it. However, the text in the file stops at 5, and I cannot debug this. (The program given below is the minimum program that illustrates the issue, and my overall objective is to store data from 6 ADC inputs every millisecond for about a week on an SDCard. I am deliberately opening and closing the file at over iteration of the loop).
Hardware: Pyboard 1.1, using with OSX.
Thanks for the help!
MAIN.PY
c = 0
while c< 100:
pyb.delay(100)
f = open('data.txt', 'a')
f.write(str(c)+'\n')
f.flush()
f.close()
c = c+1
jickster
Re: Writing to a local file is giving an error
Post by jickster » Fri Oct 12, 2018 9:46 pm
You should add exception handling to make sure that you’re open and your writes actually work.
This way you’ll be able to distinguish a software error from a hardware error
analogdiode
Post by analogdiode » Fri Oct 12, 2018 11:25 pm
I assume we want to add a try exception like so:
<code>
with open('dat.txt', 'a') as f:
while c< 100:
pyb.delay(100)
f.flush()
c = c+1
f.close ()
except OSError as exc:
print("Error is:" + exc)
</code>
I tried this two ways:
(a) Name this file as main.py, and try to observe error statement on REPL: In this case the REPL hangs, but a dat.txt file is created with numbers 0 thru 5.
(b) Name this file as main1.py, and run this as "import main1" on REPL: In this case the program produces no error statement, but no dat.txt file is created.
I wonder if this is linked to the USB also being used to mount the flash. So it tried "pyb.usb_mode('VCP') in boot.py, and then later when I booted in safe mode, I find that while dat.txt is created, it's contents seem to be garbage.
Any suggestion on what I might try next? Thanks!
[quote=jickster post_id=30995 time=1539380785 user_id=3167]
[/quote]
analogdiode
Post by analogdiode » Sat Oct 13, 2018 2:51 am
Figured it out.... use of "pyb.usb_mode('VCP')" is required in boot.py, and after that to see the data collected you have to boot in safe mode. I was probably making some mistake trying to boot in safe mode.
