Flash Read Error on ESP 32 Board
Zenith22
Post by Zenith22 » Tue Oct 23, 2018 2:10 am
Today I received my ESP32 board in the mail. I followed a guide and successfully erased the flash and installed the latest ESP32 release. Unfortunately, when I connected to my ESP32 with putty I was greeted with this message.
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
Everything was going smoothly and Micropython was installed but I keep getting this error. It keeps repeating over and over very quickly. I tried uploading an Arduino script and that worked just fine. I tried using ampy but couldn't get a directory listing. I am just a beginner so if anyone has a solution please thoroughly explain how to do it.
Flashing Code:
esptool.py -p com10 -c esp32 -b 150200 erase_flash
esptool.py -p com10 -c esp32 -b 150200 write_flash --flash_size=detect 0 file.bin
I used the latest bin files as of today, and I tried both the SPIRAM version and the regular version.
Board: https://www.aliexpress.com/item/LOLIN-D ... 16057.html
Thanks!
obetbal
Re: Flash Read Error on ESP 32 Board
Post by obetbal » Wed Dec 05, 2018 4:53 am
please verify your baud rate - 150200 ???
Standard baud rates include 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 38400, 57600, 115200, 128000 and 256000 bits per second.
Post by Roberthh » Wed Dec 05, 2018 6:16 am
The target address for loading must be 0x1000, not 0, e.g.
esptool.py -p com10 -c esp32 -b 460800 erase_flash
esptool.py -p com10 -c esp32 -b 460800 write_flash --flash_size=detect 0x1000 file.bin
For flashing, the speed can be higher. The default is 460800, but can indeed also be lower at the rates, @obetal mentioned.
wr300000
Post by wr300000 » Fri Dec 07, 2018 3:00 pm
ets_main.c 371
Flashing Code:
Thanks!
