Debug main.py at runtime
rp346@njit.edu
Post by rp346@njit.edu » Fri Nov 23, 2018 2:16 pm
How do I debug main.py file at runtime. I am in a situation where I have boot.py and main.py on ESP32 running micropython.
When the board starts up boot.py works perfectly because ESP32 connects to WIFI. But main.py which has application code doesn't run (my assumption). If I run main.py manually with following command it works, but not by the system itself.
ampy -p /dev/tty.SLAB_USBtoUART run main.py
Anyone know how can I debug main.py ?
- roy
HermannSW
Re: Debug main.py at runtime
Post by HermannSW » Fri Nov 23, 2018 5:22 pm
Write a file as 1st step in main.py (f=open("main.dbg","w") ...), then power cycle module and see (uos.listdir()) whether file was written or not.
Pico-W Access Point static file webserver:
https://github.com/Hermann-SW/pico-w
Tiny MicroPython robots (the PCB IS the robot platform)
viewtopic.php?f=5&t=11454
webrepl_client.py
https://github.com/Hermann-SW/webrepl#webrepl-shell
Post by pythoncoder » Sat Nov 24, 2018 6:04 am
The best approach is to put your code into a module and debug that at the REPL. When it's working, adapt main.py simply to import and run your module. That way main.py is extremely simple.
