uasyncio beep class
devnull
uasyncio beep class
Post by devnull » Thu Nov 29, 2018 10:31 am
Struggling to get started with uasyncio having never used it before.
I am attempting to create a beep class and this is my best guess on how to implement it, what am I doing wrong ??
gpio8266 is just a file containing pin number > name assignments.
import uasyncio as asyncio
import gpio8266 as gpio
class Beep:
  def __init__(self):
    self.rep    = 0
    self.pause  = 50
    self.dur    = 10
    loop.create_task(self.run())
  async def run(self):
      for i in range(self.rep):
        gpio.bpin.value(1)
        await asyncio.sleep_ms(self.dur)
        gpio.bpin.value(0)
        await asyncio.sleep_ms(self.pause)
      self.rep = 0
  def go(self,rep=1,dur=10,pause=50):
    self.dur = dur
    self.pause = pause
    self.rep = rep
b = Beep()
async def test():
    await asyncio.sleep_ms(2000)
    b.go(2)
loop.create_task(test())
loop.run_forever()
devnull
Re: uasyncio beep class
Post by devnull » Thu Nov 29, 2018 12:06 pm
is it possible to create standalone classes with asyncio that can then be called outside of an asyncio loop or does it mean that if you want to use an asyncio class then the entire code needs to be based on asyncio ?
Post by pythoncoder » Fri Nov 30, 2018 5:57 am
See my answer to your query on GitHub.
Regarding your code above, you're on the right lines but there is some confusion about when .run() executes. In my view it shouldn't run continuously but only when awaited. The code can be simplified thus (I haven't tested this):
class Beep:
  async def run(self,rep=1,dur=10,pause=50):
      for i in range(rep):
        gpio.bpin.value(1)
        await asyncio.sleep_ms(dur)
        gpio.bpin.value(0)
        await asyncio.sleep_ms(pause)
b = Beep()
async def test():
    await b.run(2)
loop.run_forever()
In this incarnation the class is clearly redundant and run() could simply be a function.
As a general point I doubt that beep() will produce good audio, especially in the context of a more complex uasyncio application. This is because the delays in uasyncio.sleep_ms() are highly variable: the time is a minimum. As context switching occurs when it sleeps, the maximum time depends on the number and behaviour of other coroutines.
