Error building esp8266 port on pfalcon's branch
mattzz
Post by mattzz » Sat Dec 01, 2018 1:54 pm
I'm trying to build ports/esp8266 on pfalcon's branch/fork of micropython
I am on 8f429c8426ff2ea4d1d080ca24d179dedaebc1f2
Compiling master branch works fine.
Compiling pfalcon branch results in an error:
MPY modules/picoweb/__init__.py
MPY modules/picoweb/utils.py
GEN build/frozen_mpy.c
CC build/frozen_mpy.c
CC strtoll.c
CC main.c
CC help.c
CC esp_mphal.c
CC esp_init_data.c
CC gccollect.c
gccollect.c:36:1: error: unknown type name 'mp_uint_t'
 mp_uint_t gc_helper_get_regs_and_sp(mp_uint_t *regs);
gccollect.c:36:37: error: unknown type name 'mp_uint_t'
gccollect.c: In function 'gc_collect':
gccollect.c:43:5: error: unknown type name 'mp_uint_t'
     mp_uint_t regs[8];
gccollect.c:44:5: error: unknown type name 'mp_uint_t'
     mp_uint_t sp = gc_helper_get_regs_and_sp(regs);
gccollect.c:44:5: error: implicit declaration of function 'gc_helper_get_regs_and_sp' [-Werror=implicit-function-declaration]
cc1: all warnings being treated as errors
make: *** [build/gccollect.o] Error 1
gc_helper_get_regs_and_sp is defined in gchelper.s, however, in the verbose compile output (make V=1) I can't find any reference about gchelper.o.
Am I missing something?
Thanks,
/Matthias
jomas
Re: Error building esp8266 port on pfalcon's branch
Post by jomas » Sat Dec 01, 2018 2:48 pm
is the problem. mp_uint_t is not defined.
You can fix this by including mpconfigport.h in the beginning of file: gccollect.c
Post by pythoncoder » Sat Dec 01, 2018 5:05 pm
Raise an issue against that fork?
pfalcon
Post by pfalcon » Sat Dec 01, 2018 8:40 pm
Thanks for the report. Turns out, CI wasn't run on esp8266 port for a while, both in mainline in my fork. Fixed and confirmed via CI: https://travis-ci.org/pfalcon/micropyth ... /462270955
Note that my branch is rebased. To pull new changes, you always need to use "git pull --rebase".
Awesome MicroPython list
