WS2813 RGB LED strip driver
kamikaze
Post by kamikaze » Wed Dec 05, 2018 12:18 am
Hello. Is there any library / sample code on how to get WS2813 working with PyBoard? Thanks
shaoziyang
Re: WS2813 RGB LED strip driver
Post by shaoziyang » Wed Dec 05, 2018 2:40 am
There is only SPI drive for WS2812/2813 now.
rhubarbdog
Post by rhubarbdog » Fri Dec 14, 2018 4:38 am
have you got an example of SPI being used to light some neopixel?
Post by Roberthh » Fri Dec 14, 2018 6:16 am
I tested the code for WS2812 below with a Pycom device and a 24 Pixel ring. The SPI init/call might have to be adapted. It worked to some extend, but the timing is not very precise. There are gaps between the words when sending by SPI, and if these are too long, it is considered as reset. The data be compressed, so its only 9 bytes per WS2812 device.
from machine import SPI, disable_irq, enable_irq
from time import sleep, sleep_us
def send_spi(data, spi):
    no_pixel = len(data)
    buffer = bytearray(no_pixel * 3 * 4)
    index = 0
    for pixel in data:
        for byte in pixel:
            bits = 0
            mask = 0x80
            while mask:
                bits <<= 4
                if byte & mask:
                    bits |= 0x0e
                    bits |= 0x08
                mask >>= 1
            buffer[index] = (bits >> 24) & 0xff
            buffer[index + 1] = (bits >> 16) & 0xff
            buffer[index + 2] = (bits >> 8) & 0xff
            buffer[index + 3] = bits & 0xff
            index += 4
    sleep_us(60) # ensure initial reset
    state = disable_irq()
    spi.write(buffer)
    enable_irq(state)
data = 6 * [
    (85, 0, 0),    # green
    (0, 85, 0),    # red
    (0, 0, 85),    # blue
    (85, 85, 85),   # white
blank = 24 * [(0,0,0)]
spi = SPI(SPI.MASTER, baudrate=3200000, polarity = 0, firstbit = SPI.MSB, bits=32)
    send_spi(data, spi)
    sleep(1)
    send_spi(blank, spi)
    sleep(1)
Post by OutoftheBOTS_ » Fri Dec 14, 2018 8:02 am
A simple work around can be to use APA102 LEDs instead as they have a clock line so don't care a bout precise timings. I have driven them in python on both RPi and MicroPython
kamikaze
Post by kamikaze » Thu Dec 20, 2018 11:47 pm
Modified WS2812 driver, works for my WS2813 led strip from aliexpress
https://github.com/kamikaze/pyboard-exa ... /ws2813.py
