TMP75
roland_vs
TMP75
Post by roland_vs » Sun Dec 16, 2018 4:43 pm
Dear all,
Did anyone find or has written (and willing to publish this under MIT) a driver using a TMP75 I2C temperature sensor?
Beste regards,
Roland
mcauser
Re: TMP75
Post by mcauser » Mon Dec 17, 2018 2:15 am
I don't have one of these sensors, however, the interface seems simple enough.
http://www.ti.com/lit/ds/symlink/tmp75.pdf
Configure the sensor to use a specific resolution, 9,10,11 or 12 bit.
Read 12 bits from the temperature register.
Convert data from twos compliment to temperature in Celsius.
Scan the I2C bus for the device.
from machine import I2C, Pin
i2c = I2C(scl=Pin(5), sda=Pin(4), freq= 400000)
i2c.scan()
The device by default can be found at 0x48, so you should see [72].
You can change the address by pulling A0,A1,A2 to GND.
Read the config register.
config = i2c.readfrom_mem(0x48, 0x01, 1)
bit0 = shutdown mode (power savings)
bit 1 = thermostat mode (0=comparitor, 1=interrupt)
bit 2 = alert polarity
bits 3,4 = fault queue (number of failed measurements)
bits 5,6 = resolution (00=9bit, 01=10bit, 10=11bit, 11=12bit)
bit 7 = one shot (performs one measurement then shuts down)
Set the resolution.
resolution = 12  # allowed values are: 9,10,11,12
config &= ~0x60  # clear bits 5,6
config |= (resolution - 9) << 5  # set bits 5,6
i2c.writeto_mem(0x48, 0x01, config)
Read the temperature register.
data = i2c.readfrom_mem(0x48, 0, 2)  # read 2 bytes from device 0x48 starting at address 0
# each bit represents 0.0625 degrees Celsius.
# negative numbers are represented in binary 2s complement format.
def twos_comp(val, width):
	if val >= 2**width:
		raise ValueError("Value: {} out of range of {} bit value".format(val, width))
		return val - int((val << 1) & 2**width)
temp = data[0] << 4 | data[1] >> 4  # ignore the 4 least significant bits of the 2nd byte
temp = twos_comp(temp, 12) * 0.0625  # convert to Celsius
print(temp)
mcauser
Re: TMP75
Post by mcauser » Mon Dec 17, 2018 2:16 am
Should also work for other TMPx75 sensors, TMP275, TMP175 etc.
roland_vs
Re: TMP75
Post by roland_vs » Thu Dec 20, 2018 11:07 pm
TNX's
Happy XMAS
R
