BMI160 9DOF IMU with pyboardV11
lnsri22
Post by lnsri22 » Wed Dec 19, 2018 1:19 pm
Hello Everyone!!
I have been trying to find out a 9DOF IMU to interface with the Pyboard(V1.1) that I have been playing around and planning to give a try on BMI160 IMU from Bosch. Has anyone given a try so far with this or any kind of 9DOF IMUs?
I am planning to use this library https://github.com/micropython-IMU/micropython-fusion by Peterhinch.
Thanks in advance!!
lnsri22 :)
marfis
Re: BMI160 9DOF IMU with pyboardV11
Post by marfis » Wed Dec 19, 2018 4:57 pm
I used the 9DOF sensor on the SenseHat and managed to use it together with peters fusion library that you have linked.
viewtopic.php?f=5&t=1693
lnsri22
Post by lnsri22 » Wed Dec 19, 2018 6:37 pm
Thank you so much for getting back so quick!!
That was pretty interesting :P .
I have been looking to use the IMU part alone. I may even use the env sensor later.
Would you be able to suggest on any break-out boards to start off with ??
lnsri22 :)
marfis
Post by marfis » Thu Dec 20, 2018 6:57 am
Do you mean with the bosch sensor? No I cant give recommendations there.
The SenseHat though is great value for getting things to work quickly. It may be a bit big though.
I‘m not sure if the lsm9ds1 sensor from ST on the SenseHat is a bit outdated now since the board has been around for some time. You might check ST website for some eval kits on follow up models.
A breakout board for the ST sensor is still available https://www.st.com/content/st_com/en/pr ... 159v1.html
for around 15$
lnsri22
Post by lnsri22 » Tue Jan 22, 2019 9:30 am
Thanks for the reply there!!
Will give a try and let you know :D
lnsri22 :)
Post by OutoftheBOTS_ » Tue Jan 22, 2019 9:47 am
I mainly use the very popular MPU9250, it has both become very cheap and a recognized as 1 of the best performing IMUs
lnsri22
Post by lnsri22 » Tue Jan 22, 2019 10:04 am
Thanks OutoftheBOTS_ for the suggestion!!
Will take a look and get back :)
lnsri22 :)
themaire
Post by themaire » Thu Feb 07, 2019 1:11 pm
Hi. I am actually working with a couple of BMI160. At this moment, I am just understand the raw acceleration values, rest to code the calibration.
This is the first time I learn how work a IC from zero and I am served with this complexity.
Who write own BMI160 library? Thanks.
