install earlier version of lib
amirfh
Post by amirfh » Wed Dec 26, 2018 12:07 am
How to install specific version of lib , i got this message when try to install logging lib :
>>> import upip
>>> upip.install('micropython-logging==0.4.1')
Installing to: /lib/
Warning: pypi.org SSL certificate is not validated
Error installing 'micropython-logging==0.4.1': Package not found, packages may be partially installed
mattyt
Re: install earlier version of lib
Post by mattyt » Sun Jan 06, 2019 7:52 am
Currently upip can only install the latest version of a package. See upip.py:175.
I'll try and raise a pull request to allow different versions to be installed.
In the meantime the workaround is to simply download the library you require and copy the files to your device.
