MicroPython Documentation Discussion
flywire
Post by flywire » Fri Jan 04, 2019 6:11 am
What is the best way to comment on MicroPython documentation at http://docs.micropython.org/en/latest/index.html
flywire
Re: MicroPython Documentation Discussion
Post by flywire » Fri Jan 04, 2019 6:27 am
Quick reference for the ESP8266, Networking
def do_connect():
    wlan.active(True)
    if not wlan.isconnected():
        wlan.connect('essid', 'password')
        while not wlan.isconnected():
            pass
    print('network config:', wlan.ifconfig())
This is right under Installing MicroPython, at least add a line to call the function.
WebREPL (web browser interactive prompt)
If you disabled automatic start-up on boot...
in boot.py
...but the daemon is also started on STA interface if it is active, so if your router is set up and works correctly, you may also use WebREPL while connected to your normal Internet access point...
good place for a link to Quick reference for the ESP8266, Networking
tannewt
Post by tannewt » Mon Jan 07, 2019 5:31 am
The source for those docs is in the repo itself. Here is the ESP quickref: https://github.com/micropython/micropyt ... ickref.rst
flywire
Post by flywire » Mon Jan 07, 2019 11:08 am
The source ... [is]: https://github.com/micropython/micropyt ... ickref.rst
Thank you, easy to edit with the pencil icon. :D
172 pull requests - hard to implement. :(
flywire
esptool.py erase all flash before writing (single command)
Post by flywire » Wed Jan 09, 2019 9:37 am
wrote:
Wed Jan 09, 2019 7:46 am
https://github.com/espressif/esptool/releases/tag/v2.6
Version 2.6 Features:
New write_flash --erase-all ... option to erase all flash before writing (single command).
mattyt
Post by mattyt » Sun Jan 27, 2019 5:13 am
Hi flywire, sorry for the lack of communication, things were a little hectic in the lead-up to the 1.10 release! Right here is a good place to discuss documentation though of course, raising PR's or issues is helpful too.
If you do raise a PR please let me know and I'll push to get it integrated; I'm trying to help out with the documentation.
vdb_peter
Post by vdb_peter » Thu Feb 14, 2019 1:28 am
Hi mattyt
Can a note be added to the ESP8266 Documentation on the "maximum Period" a timer can be set to, please?
I can confirm that the MAXIMUM value is 6870947 (1:54:30.947).
Please see viewtopic.php?f=16&t=5116&start=10 where this has been discussed.
Peter
