Looking for a board with 16 ADC channels and WiFi
CraigUK
Post by CraigUK » Fri Jan 11, 2019 12:22 pm
Hi all,
I have a lot of analogue sensors (16 ish) to measure and publish over wifi.
Currently I'm using the nodeMCU which has only 1 ADC, so I'm looking for a board with more ADC.
The CC3200 seems to have 4 (assuming they can all be used), are there other boards with more ADC?
Perhaps I can extend a board with an ADC add-on module?
Any advice is appreciated.
Craig
Re: Looking for a board with 16 ADC channels and WiFi
Post by Roberthh » Fri Jan 11, 2019 1:45 pm
The CC3200 board (Wipy1) is discontinued. The ESP32 has principally 16 channels, but most board break out only a subset of them. Besides that, the ESP32 ADC is bad, like the ESP8266 (nodemcu) one. You can alsways usd external ADCs, like based on an ADS1115 or others, which are connecetd to the MCU board by I2C or SPI. The quality of these ADCs is typicall way better than the built-in ADC.
PyBoard also has 16 ADC channels, and the ADC is fine, but no built-in WiFi.
ThomasChr
Post by ThomasChr » Fri Jan 11, 2019 2:02 pm
Question is: How many ADCs will the new Pyboard D bring along? I guess enough and also WiFi!
chuckbook
Post by chuckbook » Fri Jan 11, 2019 3:54 pm
PYBD allows 16 ADC channels spread on two or three ADCs.
deshipu
Post by deshipu » Fri Jan 11, 2019 4:25 pm
Just use your NodeMCU and add an external ADC chip. For example, here is a library for ads1015, which has a lot of cheap breakouts available: https://bitbucket.org/thesheep/micropython-ads1015/
CraigUK
Post by CraigUK » Sat Jan 12, 2019 10:08 am
Thanks for the info.
The PYBD sounds like a great fit but unless I'm mistaken it's not yet available? Which MCU/adc does it use?
Can I use multiple ads1015 on a single i2c bus?
Post by Roberthh » Sat Jan 12, 2019 11:07 am
You can use up to four ADS1015 or ADS1115 on a single I2C bus, if you configure the address Pin accordingly.
CraigUK
Post by CraigUK » Mon Jan 14, 2019 4:19 pm
I'll be investigating the ads devices further but will be looking into the PYBD in due course.
Thanks all!
