Bug with micropython.const
Polo
Post by Polo » Tue Jan 22, 2019 1:11 pm
This seems like a bug to me:
MicroPython v1.9.4-740-gdc23978dd on 2018-12-10; PYBv1.1 with STM32F405RG
>>> from micropython import const
>>> a = const(1)
>>> b = const(int(1))
  File "<stdin>", line 1
SyntaxError: constant must be an integer
>>> c = const(a+1)
const is failing with b and c even though the values are integers.
Re: Bug with micropython.const
Post by pythoncoder » Tue Jan 22, 2019 4:45 pm
I'm not sure why b) fails. But c) will fail because the expression put into const() must be capable of evaluation at compile time. Assigning a Python variable fails this test.
Using const() at the REPL is ineffective. It is only meaningful in scripts, where the compiler can save bytecode (and runtime) by assigning its numeric value directly rather than indirectly through a variable.
Polo
Post by Polo » Wed Jan 23, 2019 1:38 pm
Oh, I see.
So this is perfectly normal since b is not available at compile time?
# test.py
b = const(1)
# main.py
from test import b
a = const(1)
c = const(a + 1)  # works
d = const(b + 1)  # SyntaxError: constant must be an integer
I'm still a little confused on the subject of what gets compiled and what gets evaluated in Python
Post by pythoncoder » Thu Jan 24, 2019 6:40 pm
In your example b is a variable exported by module test. The compiler can't possibly know its value because code in test might modify it at runtime. A module can only export variables. The const notion is MicroPython specific: the Python language has no notion of constants. It's a performance optimisation. In essence it accepts expressions containing integer literals or other constants defined in the same module. The expression must return an integer.
Polo
Post by Polo » Mon Jan 28, 2019 10:39 am
That makes sense. Thank you
