Feed hardware watchdog timer while in deep sleep
newb
Post by newb » Thu Jan 24, 2019 6:46 am
Is it possible to feed hardware watchdog timer such as STWD100 while esp8266 is in deep sleep? Depending on the particular model the WDT's maximum timeout is between 2.24ms and 142ms, but I put my esp8266 for about 30min in deep sleep. I assume you can't work with the esp8266 pins while it's in deep sleep?
Online
kevinkk525
Re: Feed hardware watchdog timer while in deep sleep
Post by kevinkk525 » Thu Jan 24, 2019 7:39 am
No you can't work with anything on the esp8266 while in deep sleep. That's why it's called deep sleep.
newb
Post by newb » Thu Jan 24, 2019 8:24 am
Thanks, Kevin. On a second thought, any hangs would happen while esp8266 is working, not in deep sleep mode, so feeding the hardware WDT wouldn't be a problem. Am I right?
Online
kevinkk525
Post by kevinkk525 » Thu Jan 24, 2019 8:33 am
You should feed the hardware WDT when the esp is running and disabled it before deep sleep if it supports it.
newb
Post by newb » Thu Jan 24, 2019 2:01 pm
..and disabled it before deep sleep if it supports it
Aha! Thanks for the idea :D
