How to disable autoconnect ("no ap found, reconnect after 1s")?
eltomek
Post by eltomek » Sun Feb 24, 2019 11:57 am
Even though my main.py and boot.py scripts do not contain WIFI connection calls (nor credentials), micropython seems to remember the credentials and keeps reconnecting every second, yielding a notification "no ap found, reconnect after 1s".
Also, despite providing new (incorrect credentials just for the sake of testing), the ESP8266 still uses the previous ones (the correct ones).
How can I disable it?
kevinkk525
Re: How to disable autoconnect ("no ap found, reconnect after 1s")?
Post by kevinkk525 » Sun Feb 24, 2019 4:49 pm
Just disable the wifi interface completely.
Kevin Köck
jedie
Post by jedie » Mon Jan 06, 2020 5:48 pm
Interesting... So it's **always** needed to add something like this in boot.py:
network.WLAN(network.STA_IF).active(False)  # WiFi station interface
network.WLAN(network.AP_IF).active(False)  # access-point interface
Unless the device is always operated in the same wifi and that is always available.
So quite unlikely.
jedie
Post by jedie » Mon Jan 06, 2020 6:04 pm
Ah, ok. I first thought the device was stuck in a loop and boot.py/main.py was not called. But this is not the case.
I test it with this script:
import utime
if __name__ == '__main__':
    print('Set wrong WiFi settings...')
    sta_if.active(True)
    sta_if.connect('NotExisting SSID', 'No password')
    print('Hard-Reset...')
    utime.sleep(1)
    machine.reset()
So i get the connect message loop, but main.py is called and runs... So it's not needed to do anything. Great :P
