Pulse counter support
Re: Pulse counter support
Post by OutoftheBOTS_ » Thu Aug 01, 2019 8:40 pm
pidou46 wrote:
Thu Aug 01, 2019 5:53 am
It seems able to handel encoders: https://docs.espressif.com/projects/esp ... /pcnt.html
- it count rising and/or falling edge
- a filter can be set to avoid glinches
- up to 8 counter are availables, not as much as STM32, but it enable quite sophisticated projects.
But now the hardest part is how to bring it to esp32 micropython port ?
My C skills dates from ages, and I have no idea where to start with ? I guess setting up a toolchain (GCC, ESP-IDF, ect...)
Is there somewhere a tutorial or even a sample of ported fonctionality ?
Thanks for the link to the info. The info isn't detailed but from what I read it won't read an quadrature encoder. It does have a 2 pin mode but from what I can gather it works by 1 pin is the counter pin and the other pin is a direction pin (something like a stepper motor driver). A quadrature encoder works differently were both pins are counter pins but depending on the order of the rising and falling of the 2 pins whether it is counting up or down.
The PCNT would be great to have added for reading single channel encoder but not sure if it will be capable of reading a quadrature encoder
see STM32F407 encoder mode that is capable of both single and quadrature encoders https://www.st.com/content/ccc/resource ... %2Cnull%5D
Post by OutoftheBOTS_ » Sat Aug 03, 2019 6:55 am
If you really want to use ESP and need to count a number of Quadrature encoders then you might be interested in this https://lsicsi.com/products/Development ... /LS7366RSh it has 6 32bit quadrature counters and is read by SPI. It is an ardunio shield made by the manufacturer of the LS7366R chip
elliotwoods
Post by elliotwoods » Wed Dec 04, 2019 8:14 am
Hah interesting
I was looking into this exact same thing today.
I implemented to C side of things:
https://github.com/elliotwoods/ESP32-Qu ... master/src
Now I'm looking into making it a MicroPython module for my own use
To note : you can use the ESP32's hardware counter.
It works perfectly.
If A rises high and B is low, count up
If A rises high and B is high, count down
Look at the states of A and B to get an 'addition factor' to multiply your resolution by 4 (check Encoder.cpp at link above)
pidou46
Post by pidou46 » Tue Dec 24, 2019 9:57 am
Hi elliotwoods,
Did you complete the python side ?
I think you are really close to bring this functionality to MP.
If you can post it here, maybe someone (maybe me) would be able to implement it in esp32 branch in time for 2.0 release ?
Anyhow, thanks to have shared.
nodemcu V2 (amica)
micropython firmware Daily build 05/31/2016
mcauser
Post by mcauser » Tue Dec 24, 2019 11:54 pm
Here's how I attempted to add the SigmaDelta peripheral:
https://github.com/micropython/micropyt ... 5452/files
It's a very simple peripheral, but shows you the pieces needed.
The Pulse Counter peripheral is much more complex.
It uses interrupts, so might be able to pinch some code from:
https://github.com/micropython/micropyt ... ne_timer.c
Something I'm going to look into further after the holidays.
sengp
Post by sengp » Mon Feb 03, 2020 11:39 am
micropython already supports interfacing to quadrature encoded signals, e.g. rotary encoders, based on the pulse counter unit available on ESP32.
See: https://forum.littlevgl.com/t/example-f ... er/1509/20
My software (polling) and pin interrupt based approaches to implement a rotary encoder interface on the ESP32, all failed. But this hardware based approach works very well when on rotary encoders like e.g. ALPS EC11 or BOURNS PEC11L.
Have fun :),
Peter
