The SSD1306 library doesn't seem to ship in the ESP32 build
IainColledge
Post by IainColledge » Fri Mar 01, 2019 8:52 am
When using an ESP8266 one can:
import ssd1306
And the library is found, when doing the same on an ESP32 it isn't and you have to manually copy it up first.
Is this how it's meant to be?
fstengel
Re: The SSD1306 library doesn't seem to ship in the ESP32 build
Post by fstengel » Fri Mar 01, 2019 4:29 pm
Just to be on the safe side, what does
help('modules')
answer? It gives you a list of the modules that are installed with the firmware.
danielm
Post by danielm » Fri Mar 01, 2019 5:58 pm
You need to place the module into this folder during build time:
https://github.com/micropython/micropyt ... 32/modules
IainColledge
Post by IainColledge » Fri Mar 01, 2019 8:06 pm
Thanks but this is the build offered as a download, just noticed the ESP8266 build included it, the ESP32 does not.
Intention?
Online
Post by Roberthh » Fri Mar 01, 2019 8:21 pm
Yes, you are right. It is in the standard build for ESP8266, but not in the daily builds for the ESP8266, and not in the ESP32. If you want to use it there, just upload it to the ESP32. The driver is at: https://github.com/micropython/micropyt ... ssd1306.py
IainColledge
Post by IainColledge » Sat Mar 02, 2019 11:12 am
Thanks for that and I do, might be worth a mention on the builds page as without knowing newcomers would think something is broken when following the documentation.
