[pyboard clone] SSD1306 - TypeError: object with buffer protocol required
douggilliland
Post by douggilliland » Sun Mar 24, 2019 7:00 pm
I'm trying to get an SSD1306 working with a clone of the pyboard. I did search the forum and found a couple of other complaints about the same issue but didn't follow the solutions they offered there.
Code is pretty simple:
import machine, ssd1306
i2c = machine.I2C(1)
oled = ssd1306.SSD1306_I2C(128, 64, i2c, 60)
oled.fill(0)
oled.text("Hello World", 0, 0)
oled.show()
Getting back error message:
>>> import ssdTest
File "ssdTest.py", line 3, in <module>
I2C scan shows:
>>> import machine
>>> i2c=machine.I2C(1)
>>> i2c.scan()
[33, 60]
The 33 is a MCP23008 I2C port expander and the 60 is the OLED display so I'm pretty sure the I2C is connected. I do talked to an MCP23008 on the connection earlier today.
The offending line seems to be:
Using ssd1306.py library and the initializer for the function looks like:
class SSD1306_I2C(SSD1306):
def __init__(self, width, height, i2c, addr=0x3c, external_vcc=False):
>>> sys.version
'3.4.0'
>>> sys.platform
'pyboard'
Any help is appreciated. Thanks!
brian park
Re: [pyboard clone] SSD1306 - TypeError: object with buffer protocol required
Post by brian park » Sat Jun 15, 2019 12:43 pm
same here. did you fix this problem?
Post by jimmo » Sat Jun 15, 2019 1:16 pm
>>> sys.version
'3.4.0'
This is the Python version, could you please also let us know the MicroPython version? sys.implementation
Could you check the same please?
If you're using the latest version of ssd1306.py, you'll need to be running MicroPython v1.11. https://micropython.org/downloads
