SDRAM module
SDRAM module
Post by OutoftheBOTS_ » Wed Mar 27, 2019 9:12 pm
Does anyone know if this really cheap 32meg SDRAM module can be made to work on a STM32 MCU https://www.aliexpress.com/item/256Mbit ... 83b54ebd0b
Re: SDRAM module
Post by pythoncoder » Fri Mar 29, 2019 10:35 am
If you're talking about increasing heap memory the answer is no. The necessary hardware interface is unavailable.
[EDIT]Apologies for the noise. I was unaware of the FSMC.
marfis
Re: SDRAM module
Post by marfis » Fri Mar 29, 2019 1:37 pm
Not too sure but STM32’s FMC peripheral does have support for SDRAM
it is apparently supported / enabled in some of the boards, e.g here
https://github.com/micropython/micropyt ... oard.h#L97
but I havent tried it. The comment indicates it can be used for heap.
Re: SDRAM module
Post by OutoftheBOTS_ » Sat Mar 30, 2019 8:17 am
I have used the FMSC peripheral to write to the RAM of a TFT in 16bit parallel in C. See this code https://github.com/OutOfTheBots/ili9341_16bit_touch was part of the development for this video https://www.youtube.com/watch?v=H51OzQl3BC8&t=8s
Do you know for sure if the FSMC will support SDRAM or only SRAM and PSRAM??
marfis
Re: SDRAM module
Post by marfis » Sat Mar 30, 2019 8:20 pm
According to the reference manual for the F7:
https://www.st.com/content/ccc/resource ... 124865.pdf
page 307,
The FMC functional block makes the interface with: synchronous and asynchronous static memories, SDRAM memories, and NAND Flash memory
and
Interface with synchronous DRAM (SDRAM/Mobile LPSDR SDRAM) memories
The micropython repository supports the STM32F7 discovery kit: https://www.st.com/en/evaluation-tools/ ... overy.html it includes 128 MBits of SDRAM. FMC is enabled in mpconfigboard.h, so it should run out of the box.
Re: SDRAM module
Post by OutoftheBOTS_ » Sat Mar 30, 2019 9:40 pm
Thanks a lot this answers my question.
Not that I need 32meg of SDRAM it would be an interesting learning curve for me to buy 1 of these cheap modules and made it work :)
marfis
Re: SDRAM module
Post by marfis » Sun Mar 31, 2019 1:10 pm
made it work
i‘d also be interested if this is going to work, let me know how it has turned out.
exider
Re: SDRAM module
Post by exider » Tue Nov 05, 2019 2:30 pm
Hi OutoftheBOTS,
Did you wrap that c code in python? Asking as I have one of those Acelex tft displays that the pins correspond to those 16bit fsmc pins of the board and would be great if I can make use of it in micropython.
If so, would you mind sharing the code?
Re: SDRAM module
Post by OutoftheBOTS_ » Tue Nov 05, 2019 9:45 pm
No I haven't :(
My business has been super busy lately and I have been working more than 12hrs a day and 7 days a week for last couple of months. On my short list is to build a robot for a comp coming up next year.
What is on my list to do is to write a pure python implementation using viper mode of the 16 bit TFT interface using the FMSC peripheral but not sure when I will get time to do this.
