ure.sub not available in v1.10?
ProudPagan
Post by ProudPagan » Fri Apr 12, 2019 9:02 am
I am developing my MicroPython code on Windows and I see an error when trying to use ure.sub ...
However, the docs say this should be available.
D:\micropython.exe
MicroPython v1.10-278-g673e154df on 2019-04-12; win32 version
Use Ctrl-D to exit, Ctrl-E for paste mode
>>> import ure
>>> xx="a simple test"
>>> ure.sub('^a', '', xx)
AttributeError: 'module' object has no attribute 'sub'
andymouse
Re: ure.sub not available in v1.10?
Post by andymouse » Fri Apr 12, 2019 10:20 am
I just typed this does it help as I'm just starting out ?
>>> import ure
>>> help(ure)
object <module 'ure'> is of type module
__name__ -- ure
compile -- <function>
match -- <function>
search -- <function>
sub -- <function>
DEBUG -- 4096
Andy
ProudPagan
Post by ProudPagan » Fri Apr 12, 2019 3:55 pm
I get this:
>>> help (ure)
NameError: name 'help' isn't defined
I seem to be missing something.
Post by Roberthh » Sat Apr 13, 2019 6:11 am
The Windows version of MicroPython is somewhat limited. For whatever reason the help module is not included. Other modules may be missing too. Did you build that version yourself, or where did you get that from
ProudPagan
Post by ProudPagan » Sat Apr 13, 2019 6:31 am
I compiled MicroPython from the Github sources at:
https://github.com/micropython/micropyt ... ts/windows
cross compiled for Windows using Ubuntu sub-system.
Thanks.
I can't explain this
Post by pythoncoder » Sat Apr 13, 2019 7:07 am
This is an aspect of MicroPython that I find baffling, despite nearly 5 years involvement.
tl;dr the availability of features is often in inverse proportion to the capabilities of the hardware.
On the Unix build:
>>> dir(ure)
['__class__', '__name__', 'DEBUG', 'compile', 'match', 'search']
On a Pyboard D:
>>> dir(ure)
['__class__', '__name__', 'DEBUG', 'compile', 'match', 'search', 'sub']
On an ESP8266:
>>> dir(ure)
I could understand if ure.sub were omitted on a resource constrained platform like ESP8266. The converse is true. It (and other features) are left out on the platforms with effectively unlimited resources: PC's. Can anyone explain this?
Post by Roberthh » Sat Apr 13, 2019 12:20 pm
I compiled a version of micropython for Windows which includes ure.sub(9 and help(). You'll find it here: https://github.com/robert-hh/Shared-Stuff
And yes, it's strange that ure.sub is not included into all versions, when ist is present in the version with the strongest memory constrainst
ProudPagan
Post by ProudPagan » Sat Apr 13, 2019 12:35 pm
Thanks!
It works. I am curious how you compiled this.
Post by Roberthh » Sat Apr 13, 2019 2:02 pm
I used MINGW for that (https://mingw-w64.org/doku.php). No magic. Just install MINGW on Windows, download the repository and run make. I had to adapt mpconfigport.h in microypthon/ports/windows to enable these features along the line of micropython/ports/esp8266 or the other ports.
