I2C multiplexer library?
asuagar
Post by asuagar » Mon Apr 15, 2019 10:16 am
Is there a Micropython library for the TCA9548A or another multiplexer device? There is a library for the TCA9548A in CircuitPython. However, I am afraid that it will not work in MicroPython. Is there other way for multilplexing using MicroPython?
Thanks & regards!
Re: I2C multiplexer library?
Post by Roberthh » Mon Apr 15, 2019 2:00 pm
Circuitpython is a Micropython variant. The only thing to adapt is typcially the way it speaks to I2C. There are minor differences in the I2C API. I have sucessfully ported Adafruit libraries, and it was usually easy.
doublevee
Post by doublevee » Sun Apr 21, 2019 10:50 am
I have been using this mutliplexer in a product I am building and it is very easy to use. I'm not sure it needs a library at all? You select the I2C address for the mux using 3 external pins (can be IO driven or just hard wired). You then just write a single command to that address to select the output channel of the mux. The mux remains on that channel until either a power cycle or you issue a new channel command.
In brief, once you have your mux setup, it's a very small amount of code to add to select a particular device - almost a single line depending on your use case.
Happy to help further if needs be. I'm no expert at all but happy to try and help if needed.
