How to execute a frozen_module when my Nucleo32L432KC boots up?
gbergero
Post by gbergero » Thu Apr 18, 2019 8:25 pm
im using a Nucleo32l432kc flashed in Micropython and I would like to execute a python script whenever the device boots up.
Problem is, there's no file system so I can't save any code in "main.py" or "boot.py" like you would do on other Nucleo boards. The only way i found to put python code permanently on my Nucleo is to rebuild my firmware with a frozen module ("testModule.py") which worked, but its not very convenient since I have to type
import testModule
testModule.test()
everytime I reboot the device.
What I want to do is have my Nucleo execute a specific frozen module everytime it boots up. The frozen module would essentially act like "boot.py" but it wouldn't be editable without rebuilding the firmware. I already tryed modifying the main.c file
like in this thread viewtopic.php?f=2&t=3067 but it didn't work.
If anyone can help me achieve this I would really appreciate it.
Thank you
Gbergero
Re: How to execute a frozen_module when my Nucleo32L432KC boots up?
Post by dhylands » Thu Apr 18, 2019 11:15 pm
What was your code? and what exactly didn't work?
I modified my main.c so that it would execute a frozen main.py.
Here's what I just did:
1 - created a modules-l432 directory and put main.py and testModule.py in it.
main.py looks like:
print('Executing modules-432/main.py')
import testModule
testModule.test()
and testModule.py contains:
def test():
    print('Executing frozen testModule.test()')
I modified main.c:
531 >git diff main.c
diff --git a/ports/stm32/main.c b/ports/stm32/main.c
index 8c2d7d529..e7eb0c8e8 100644
--- a/ports/stm32/main.c
+++ b/ports/stm32/main.c
@@ -733,6 +733,9 @@ soft_reset:
     // Run the main script from the current directory.
     if ((reset_mode == 1 || reset_mode == 3) && pyexec_mode_kind == PYEXEC_MODE_FRIENDLY_REPL) {
+#if 1
+        pyexec_frozen_module("main.py");
+#else
         const char *main_py;
         if (MP_STATE_PORT(pyb_config_main) == MP_OBJ_NULL) {
             main_py = "main.py";
@@ -749,6 +752,7 @@ soft_reset:
                 flash_error(3);
+#endif
     // Main script is finished, so now go into REPL mode.
and executed:
make BOARD=NUCLEO_L432KC clean
make BOARD=NUCLEO_L432KC FROZEN_MPY_DIR=modules-l432
make BOARD=NUCLEO_L432KC FROZEN_MPY_DIR=modules-l432 deploy-stlink
and from the REPL if I do Control-D I see this:
MPY: soft reboot
Executing modules-l432/main.py
MicroPython v1.10-290-g8402c26cf-dirty on 2019-04-18; NUCLEO-L432KC with STM32L432KC
gbergero
Post by gbergero » Fri Apr 19, 2019 12:49 pm
Hi Dave,
Thank alot for you response, i tryed it and it worked!
MicroPython v1.10-284-ga6e5846ba-dirty on 2019-04-19; NUCLEO-L432KC with STM32L432KC
Here's what my main.c file looks like :
        if(1) {
        } else {
            main_py = mp_obj_str_get_str(MP_STATE_PORT(pyb_config_main));
        mp_import_stat_t stat = mp_import_stat(main_py);
        if (stat == MP_IMPORT_STAT_FILE) {
            int ret = pyexec_file(main_py);
            if (ret & PYEXEC_FORCED_EXIT) {
                goto soft_reset_exit;
            if (!ret) {
                flash_error(3);
It looks alot like yours but i had to modify a few lines to get it working.
