STM32 F7 Discovery
jrprogrammer
STM32 F7 Discovery
Post by jrprogrammer » Sat Apr 20, 2019 1:39 pm
Yes, they have micropython for this board but it seems the nice LCD isn't supported. Has anyone gotten the LCD incorporated into their code. I have the STM32 F746 Discovery board.
Thanks,
Jim
boochow
Re: STM32 F7 Discovery
Post by boochow » Sat Apr 20, 2019 3:13 pm
There's one for F746 Discovery
viewtopic.php?f=3&t=4718
jrprogrammer
Post by jrprogrammer » Sun Apr 21, 2019 6:47 pm
Thanks for the link!
I also found "Boot0"(with a little help)... If you look around U5, you'll see a missing resistor R42(0201 size). All you do is apply a solder bridge and suddenly can erase at will. When you're done, just remove your solder bridge...
Your mileage may vary,
JR
ta1db
Post by ta1db » Wed Sep 04, 2019 6:22 am
@boochow I am trying the bin image found on your page "http://blog.boochow.com/wp-content/uplo ... 6disco.zip" , I have downloaded the image from your web-site, programmed&verified on STM32F746G-DISCO using ST-LINK Utility, it looks like working with a blank white display, however the micropython doesn't respond to serial connections either from PuTTY or rshell.. what can be wrong? (it resides on COM3:)
Is there any newer version of SMT32F7DISCO micropython dfu or bin image somewhere else?
Post by jimmo » Wed Sep 04, 2019 7:05 am
It looks like the repo linked in the other thread -- https://github.com/forester3/micropytho ... f7disc-lcd -- has relatively up to date support for the F7 discovery. Should be pretty straightforward to rebase onto master.
ta1db
Post by ta1db » Mon Sep 09, 2019 10:10 am
[quote=jimmo post_id=39124 time=1567580728 user_id=3071]
[/quote]
it worked. thank you very much..
ta1db
Post by ta1db » Mon Sep 09, 2019 11:50 am
Here is a good code example to test the LCD Display:
import lcdF7D
lcdF7D.init()
lcdF7D.set_font(18)
lcdF7D.display_string_at_line(3,"Hello, STM32F746G-Discovery")
lcdF7D.set_font(16)
lcdF7D.display_string_at_line(5,"Good collaboration with MicroPython !")
lcdF7D.deinit()
(http://www.micropython.org.cn/bbs/forum ... d&tid=1090)
mapy
Post by mapy » Wed Sep 11, 2019 10:03 pm
Hello all, I've tryed it too and it works very well, I would like to use it on the current v1.11 version. Jimmo you mentioned "Should be pretty straightforward to rebase onto master" could you please point to any documentation on how to rebase that code?.
Thank you very much.
ta1db
Post by ta1db » Thu Sep 19, 2019 5:58 pm
...could you please point to any documentation on how to rebase that code?.
I would also appreciate very much..
Post by jimmo » Thu Sep 19, 2019 11:18 pm
Are you asking for advice on how to use"git rebase" or something specific to MicroPython?
Happy to answer both, just don't want to tell you stuff you already know.
