Using a Ethernet cable on SF6W
Picasso
Post by Picasso » Mon Apr 29, 2019 2:10 pm
Hello, what would be the preferred way to connect a pyboard-d series to a network using an ethernet cable?
Is it still the best option to use a WIZ820IO connector?
Thanks in advance!
Re: Using a Ethernet cable
Post by jimmo » Mon Apr 29, 2019 2:19 pm
Which pybd do you have? See this paragraph from newsletter #6. viewtopic.php?f=19&t=6077
The pyboard D will be offered in two variations, the standard model with an STM32F722 MCU, and the high-performance model with an STM32F767. The standard model has 256k RAM, 512k internal flash and single precision hardware floating point, while the high-performance model has 512k RAM, 2Mbyte internal flash, double precision hardware floating point, Ethernet (via adapter board), DCMI interface and other peripherals.
Hopefully coming soon?
Picasso
Re: Using a Ethernet cable on SF6W
Post by Picasso » Mon Apr 29, 2019 4:40 pm
I am looking indeed at the SF6W model.
However the project has some deadline mid may .... I dont know if I should wait for a new adapter board to come out.
So any suggestions of product I can source at this moment would be great.
wieder
Post by wieder » Wed Jun 05, 2019 11:22 am
When does the Ethernet Adapter comes?
Picasso
Post by Picasso » Wed Jun 19, 2019 1:44 pm
That is unknown at the moment.
