Home automation
fendell
Home automation
Post by fendell » Thu Apr 09, 2015 4:17 pm
Started a project of building some kind of home automation, the part I’m starting with is to control my pellets burner with the pyboard.
The pyboard will take care of the burning process and keeping the burner running with new pellets. Then I want to send all the values
to my Raspberry pi over serial that will send to my phone using socket and on the phone i will have kiwi for managing the set values and
the actual values for the burner.
How would you send many different values over serial? (Just curious for suggestions)
My first thought is combining all values in a string with a separator char to tell what values to go into the right variable.
Here is my repo with what i got so far:
https://github.com/Fendell/homeAutomation
Any suggestions or critique on my coding is appreciated
Best Regards Lars Fendell
mikewop
Re: Home automation
Post by mikewop » Thu Apr 16, 2015 4:52 am
Hi fendell,
The answer to your question probably is "it depends" :).
There are many different serial protocols already defined that all serve specific purposes, and of course you can always create your own.
If you only ever want to communicate between pyBoard and RPi, you could use just any string format
If you want something more generic or extensible that scales to multiple sensors and/or actuators take a look here:
http://openmicros.org/index.php/article ... -reference
Then there is also firmata from the Arduino-world, someone seems to have started porting this to micropython:
https://github.com/Neon22/micropython-firmata
Hope that helps,
Mike
Re: Home automation
Post by pythoncoder » Thu Apr 16, 2015 4:45 pm
Re sending values over a serial link one way is as follows. Put the various values into a Python object of your choosing, say a list or a dictionary or an instance of a class of your own design. You can then use the Python repr() function to convert the object instance to a string. This can be sent over a serial link. When it's received you re-create the original object using eval(the_string). e.g.
>>> a = 23.2
>>> b = -17.5
>>> c = "hello"
>>> d = {1:a, 2:b, 3:c}
>>> s = repr(d)
>>> s
"{1: 23.2, 2: -17.5, 3: 'hello'}"
>>> g = eval(s) # At the receiver
>>> g
>>> g[2]
-17.5
This assumes that your transmission link is reliable. If there is a chance that data might be corrupted in transmission, or if the receiver might be switched on in mid message, you start to enter the world of communication protocols. A big topic.
fendell
Re: Home automation
Post by fendell » Sat Apr 18, 2015 2:00 pm
pythoncoder wrote:Re sending values over a serial link one way is as follows. Put the various values into a Python object of your choosing, say a list or a dictionary or an instance of a class of your own design. You can then use the Python repr() function to convert the object instance to a string. This can be sent over a serial link. When it's received you re-create the original object using eval(the_string). e.g.
>>> a = 23.2
>>> b = -17.5
>>> c = "hello"
>>> d = {1:a, 2:b, 3:c}
>>> s = repr(d)
>>> s
>>> g
>>> g[2]
-17.5
yes this was in the way i was thinking, I’ll try this out. Thanks
Jessiryan
Re: Home automation
Post by Jessiryan » Tue Jul 09, 2019 8:59 am
Hey the Github link you have provided is not valid. Could you please verify the link again please?
Re: Home automation
Post by pythoncoder » Wed Jul 10, 2019 11:20 am
The github reference from @mikewop works fine here, but the openmicros.org domain is a 404.
