ESP8266 goes down after sometime [SOLVED]
navy
Post by navy » Sat May 04, 2019 6:45 am
Hi!
I have nodemcu v3 or v2 with flashed micropython inside.
There are small python script inside,that reads bme280 and send data to mqtt server of thingspeak.
So, after power on it works several days and poweroff suddenly. LED is off and no data send to server.
I wondering whys its happend? where is problem? in code or in hardware?
Please help.
Here is sources of a script:
https://pastebin.com/fF2UgVVQ
Re: ESP8266 goes down after sometime
Post by jimmo » Sat May 04, 2019 8:19 am
What makes it start working again once it gets to this state? Does the reset button fix it or do you need to remove power altogether? What power source are you using?
Do you have a multimeter that you can verify that it's still being powered?
kevinkk525
Post by kevinkk525 » Sat May 04, 2019 12:33 pm
It most likely freezes. This happens to all my esp8266 every few days. Using a software watchdog with timer interrupts that resets the board helps with that. This happens especially with cheap chinese boards and bad power supplies.
Of course there's always the possibility of your code failing becasue you don't catch any errors like an error during the connection to the server. You have to debug that too, it might not be the case that your esp freezes.
This is the stripped down version of my wdt, should give you an idea of what to do:
class WDT:
    def __init__(self, id=0, timeout=120):
        self._timeout = timeout / 10
        self._counter = 0
        self._timer = machine.Timer(id)
        self.init()
    def _wdt(self, t):
        self._counter += self._timeout
        if self._counter >= self._timeout * 10:
            machine.reset()
    def feed(self):
        self._counter = 0
    def init(self, timeout=None):
        timeout = timeout or self._timeout
        self._timer.init(period=int(self._timeout * 1000), mode=machine.Timer.PERIODIC, callback=self._wdt)
    def deinit(self):  # will not stop coroutine
        self._timer.deinit()
First thing however should be to catch exceptions and make sure you're code doesn't get stuck on an error.
Kevin Köck
Post by pythoncoder » Sun May 05, 2019 5:45 pm
I notice you're using `umqtt.simple`. This really isn't suitable for long term use because it does not properly recover from WiFi outages. Brief outages can occur for various reasons including bursts of RF interference. You might like to read this - follow the link to the resilient driver. Also these notes on why achieving reliable WiFi applications is difficult.
There are also hardware issues as referenced by @kevinkk525: I agree with his suggestion of a software WDT,
navy
Post by navy » Sun May 05, 2019 5:56 pm
Wow, thank you so much for that deep info, guys!!!
I just changed a power source, and now waiting for freeze. I use old phone charger on 5v. Just changed for different one.
Will use WDT and mqtt driver for a current project with ESP32.
navy
Post by navy » Sun May 05, 2019 6:26 pm
class WDT:
        self._counter = 0
        self.init()
    def _wdt(self, t):
            machine.reset()
    def feed(self):
        self._counter = 0
Could you kindly show me, how i should use this code? how i should proper integrate it in my code?
i just haven't any experience with object oriented programming in python.
navy
Post by navy » Sun May 05, 2019 6:40 pm
when i tried to measure voltage on esp pins, esp just started. So, i conclude, that problem is with power.
I tried to measure voltage on power source, but multimeter don't show me any values, so i just change it, maybe its broken. Or battery in my multimeter is low.
I've tested reset button after ESP waked up because of my measure tries. So i cant be sure reset working when ESP in that down state.
kevinkk525
Post by kevinkk525 » Sun May 05, 2019 7:08 pm
class WDT:
        self._counter = 0
        self.init()
    def _wdt(self, t):
            machine.reset()
    def feed(self):
        self._counter = 0
Put the class at the start of your code, then create the object: wdt=WDT()
Then inside your look call wdt.feed()
Kevin Köck
ThomasChr
Post by ThomasChr » Mon May 06, 2019 2:33 pm
Make sure that you've got everything in try/catch-Blocks.
This code: https://github.com/ThomasChr/ESP8266-re ... er/main.py
is running since 13.01.2019 without a restart.
So the ESP8266 can be very stable.
navy
Post by navy » Tue May 07, 2019 9:09 am
Hi all!
ESP8266 still working after i changed a power source. Meanwhile i've refactored code a little bit. Added a few try/except.
wdt
Kevin, explain me please where i should put wdt.feed()? actually i don't understand mechanics. If i uncomment wdt.feed() my program resets after wdt timeout even if my not freezed.
Now i am working on moving from mqtt.simple to resilient driver.
Glad to any feedback, thank you for a help guys!
import bme280_float
import micropython
# software watchdog, to prevent ESP freezing
class WDT:
        self._counter = 0
        self.init()
    def _wdt(self, t):
            print("WDT timeout")
            machine.reset()
    def feed(self):
        self._counter = 0
#wdt=WDT()
# wdt.feed() ask about right usage
WiFi_SSID = "ssid"
WiFi_PASS = "pass"
SERVER = "mqtt.thingspeak.com"
CHANNEL_ID = "777777"
WRITE_API_KEY = "00000"
led = Pin(2, Pin.OUT)
# Exception in an ISR should be handled, reserve memory for that
def collectData():
    temp1, pas1, hum1 = bme.values
    #temp1 = result[0]
    #hum1 = result[2]
    hum1 = hum1.replace("%", "")
    temp1 = temp1.replace("C", "")
    led.on()
    return temp1, hum1
    # esp8266 scl pin 5, sda pin 4
    # esp32 scl pin 22 (gpio 22), sda pin 21 (gpio 21)
    i2c = machine.I2C(scl=machine.Pin(22), sda=machine.Pin(21))
    #bme= BME280(i2c=i2c, mode=BME280_OSAMPLE_8, address=BME280_I2CADDR)
    bme = bme280_float.BME280(i2c=i2c)
    client = MQTTClient("umqtt_client", SERVER)
    topic = "channels/" + CHANNEL_ID + "/publish/" + WRITE_API_KEY
    ap_if = network.WLAN(network.AP_IF)
    ap_if.active(False)
    wlan.active(True)
    if not wlan.isconnected():
        print('connecting to network... ')
        wlan.connect(WiFi_SSID, WiFi_PASS)
        while not wlan.isconnected():
            pass
    print('network config:', wlan.ifconfig())
    print('SSID: ', WiFi_SSID)
        temp1, hum1 = collectData()
        #esp8266 bme code: payload = "field1="+str(hum1)+"&field2="+str(temp1)
        payload = "field1="+str(temp1)
        print(payload)
            client.connect()
            client.publish(topic, payload)
            client.disconnect()
        except:
            continue
        led.off()
        time.sleep(180)
except:
    print('Catched Exception in main. Reset.')
    machine.reset()
