IR encoder pyboard V1,1
Re: IR encoder pyboard V1,1
Post by OutoftheBOTS_ » Sat Jul 13, 2019 8:43 pm
johnbanes wrote:
Sat Jul 13, 2019 4:14 pm
Thank you for the help. I'm reading the output from the encoder. Had to switch to this because it's quadrature and the sensor is already 3.3v . It fits into the cheap plastic robot gear boxes with some shortening of the motor drive shaft.
https://www.ebay.com/itm/130-Motor-DC6V ... 2749.l2649
Thanks again !
If your after a complete motor, gear box, encoder, wheel and mounting bracket these are quite good for the price https://www.ebay.com/itm/1Set-GM25-370- ... Hrr4Fh0fbQ and are plug and play with 3.3v
If you want high performance motors with a gear box and encoder then these are super impressive https://www.ebay.com/itm/Japan-Namiki-C ... SwgQ9Vrga3 but to use the quadrature encoders on these you need to sell the correct resistors
