urequests and timeout?
zmaier
Post by zmaier » Fri May 31, 2019 6:44 am
Hi everyone.
when loosing the wlan-connection (e.g. i turn of the router) my programm hangs at :
response = urequests.post(db, data=payload,timeout=timeout_sec)
it is not raising a exception, the program hangs for ever at this line.
Any idea why?
How do you implement a simple post-command?
THX
Martin
I am using this urequests.py :
https://github.com/micropython/micropyt ... equests.py
fefe
Re: urequests and timeout?
Post by fefe » Fri May 31, 2019 4:46 pm
If you lose wifi connectivity it should throw an exception.
I would try wrapping the request in a try block and check to see if the wifi goes out and handle that exception. Here is a very basic example using a get request. If you're doing a post you should check if status_code != 201.
while res.status_code != 200:
            gc.collect()
            res = req.get(url=url)
            gc.collect()
        except:
            # no internet connection on chip
            if not wlan_sta.isconnected():
                  time.sleep(30)
Post by pythoncoder » Fri May 31, 2019 5:48 pm
If you lose wifi connectivity it should throw an exception...
I wish it were so. You might like to read my observations on this issue.
