CC3200 Texas instruments launchpad
TrevorNoah
Post by TrevorNoah » Thu Jun 13, 2019 11:51 am
Hello, I am trying to connect my CC3200 launch pad with my desktop despite having the correct drivers the Energia IDE is not able to upload the sketch on the launch pad. How can I resolve this issue? This is the error message I get. Energia: 1.6.10E18 (Windows 7), Board: "CC3200-LAUNCHXL (80MHz)"[url=https://sarkariresult.onl/][color=#000000]https://sarkariresult.onl/[/color][/url] [url=https://mobdro.onl/][color=#000000]Mobdro[/color][/url] [url=https://pnrstatus.vip/][color=#000000]https://pnrstatus.vip/[/color][/url]
<command-line>:0:15: warning: ISO C99 requires whitespace after the macro name [enabled by default]
Sketch uses 3,000 bytes (1%) of program storage space. Maximum is 262,144 bytes. Opening COM6 Triggering bootloader.... Trigger bootloader failed. Retrying... (1 attempt) Trigger bootloader failed. Retrying... (2 attempt) Trigger bootloader failed. Retrying... (3 attempt) Trigger bootloader failed after 3 attempts Failed to trigger bootloader An error occurred while uploading the sketch
Re: CC3200 Texas instruments launchpad
Post by jimmo » Thu Jun 13, 2019 12:35 pm
Could you provide some more information about what you're doing? What's the sketch that you're building?
I notice that you're using Windows -- from the readme https://github.com/micropython/micropyt ... /README.md for the CC3200 port, it looks like building is only supported for Linux/Mac. Perhaps you can do it on Windows using WSL...?
