uansycio.websocket.server/example_websock.py
pidou46
Post by pidou46 » Fri Jun 14, 2019 12:59 pm
Hi
I would like to run the example module of async version of websocket server from "https://github.com/micropython/micropyt ... websock.py" on a "esp32spiram-20190529-v1.11.bin"
It failed due to "websocket" library not available in the "server.py" module.
I haven't found "websocket" in micropython-lib directory, wher can I found it ?
nodemcu V2 (amica)
Re: uansycio.websocket.server/example_websock.py
Post by jimmo » Fri Jun 14, 2019 1:43 pm
It's built-in, but it's actually called uwebsocket.
Some of the "ufoo" modules are aliased (via a weak link) to the "foo" but this doesn't appear to be the case for websocket.
Sorry I don't know if there's something I'm missing - but maybe try changing the "import websocket" to "import uwebsocket" and see if that helps?
The only other thing I know that uses websocket is webrepl, which does "import uwebsocket"
pidou46
Post by pidou46 » Mon Jun 17, 2019 8:00 am
Ok, thank you
I will try when at home
nodemcu V2 (amica)
