ESP8266: instead of main.py start from REPL an script
BigMan
Post by BigMan » Sat Jun 29, 2019 11:32 am
I do a lot of try-and-error coding. Means I write a main.py and flash it on the ESP8266 with ampy. The issue is: after rebooting the ESP8266, the main.py may be started but I cannot see any error messages while main.py is executed.
It would be much better, if I access with picocom the REPL first and start from there the main.py.
My first attempt was to rename the main.py, so it doesn't get started automatically. Then I logged into the REPL with picocom, loaded os and tried os.system("main_new_name.py") ... well but os.system isn't available in µPython.
Anyhow: what is the correct approach to test µPyhton-Skripts on the ESP8266, in a way I can see in a terminal all the errors?
In advance: thanks for all your support
(Note: already searched the forum for similar issues, e.g. with the term "execute scripts" but found nothing appropriate)
Re: ESP8266: instead of main.py start from REPL an script
Post by jimmo » Sat Jun 29, 2019 11:47 am
If you put your code in foo.py, then on the repl run "import foo", you should get what you want.
Also you can use Ctrl-D to soft-reset.
Kip
Post by Kip » Sat Jun 29, 2019 11:49 am
I recently got the ESP8266 and had a play around. I made a "note to self" of my workflow. Check it out: https://github.com/KipCrossing/ESP2866-MicroPython
I put my code in a different file just in case my main.py file got corrupted. It seems difficult to remove corrupted files.
Christian Walther
Post by Christian Walther » Sat Jun 29, 2019 12:53 pm
There must be something wrong here. You should see error messages or anything else printed to stdout on the serial output while main.py is running.
BigMan
Post by BigMan » Sat Jun 29, 2019 2:24 pm
main.py will be executed automatically when the ESP8266 is powered on. Many messages will be generated long before I am able to login with picocom.
BigMan
import foo.py <- that the solution and works! Thanks!!!
