read and delete only one line of a file?
zmaier
Post by zmaier » Thu Jul 04, 2019 7:36 am
with open(infile,'r') as ifile:
   for line in ifile:
      <do something with line>
      if everthing is iO
         delete line in file
      else
	 leave line in file
How can i do that without using readlines and writelines (since the file is too big for the mem).
Re: read and delete only one line of a file?
Post by jimmo » Thu Jul 04, 2019 8:04 am
Do you have room on flash to make a new file?
i.e. with your code above, write out he current line to the new file (if you're keeping the line).
Then at the end, replace the old file with the new one. (os.unlink, os.rename).
zmaier
Post by zmaier » Thu Jul 04, 2019 11:42 am
Ok, thats a good workaround. I have enough room left, so this shouldn't be a problem.
I thought maybe there is a command which reads and deletes one line together.
THX
